C4 leaking
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: C4 leaking
http://www.oldcarmanualproject.com/manuals/trans/Ford%20C4/1971%20Ford%20C4%20Technician%20Reference%20Manual/index1.html Check this one. If you get it apart, see if it has 6 pinion planitaries.
supervel45- Posts : 4499
Re: C4 leaking
The extra wide bushing is how wide? This one is just a tick under 3/4" and made of brass I think
6jeff6- Posts : 279
Re: C4 leaking
And when looking down on trans (its stood up)gasket was ripped/cracked thru bottom right corner off of rectangular passage so hopefully that was leak spot.
6jeff6- Posts : 279
Re: C4 leaking
On the bushing, I would say that is the wide one, but nut 100% positive, but it about the size of a C6 bushing from memory. Are the bolts on the bell housing seperate from the pump? Check your PM box, but it is probably to late.
Re: C4 leaking
And I am not going that deep to see what's in there. I only loosened/tightened front band
6jeff6- Posts : 279
Re: C4 leaking
http://www.coanracing.com/PDFS/InstallInstructions/COA-72021.pdf This is what Coan wants on his transbrakes for C4 and5's. Step #6 in the link.
Re: C4 leaking
Good on the back band. What about the bell housing?
Re: C4 leaking
Looks good other then where they ground away for dipstick
6jeff6- Posts : 279
Re: C4 leaking
What I meant was if it had seperate bolts that hold it to the case, or do they go thru the bell housing and pump? I think all of the BBF bell housing's are the large style and have seperate bolts, but I am not sure.
Re: C4 leaking
Don't get me to lying. I like type F myself, but guy's seem to run all type's now. I would check around some. How was the seal grove on the torque convertor?
Re: C4 leaking
I think okay. I've seen merc III, type F and john deere tractor fluid in my searches. Just hoping guys with big blocks say something as the torque is just a tick more
6jeff6- Posts : 279
Re: C4 leaking
https://www.429-460.com/t21069-trans-fluid?highlight=fluid If you like to spend A lot of money, check this link. Last I heard Frank Merkel still recomended regular ol Type F with the C6's, and he should know. You will probably need to fill that C4 with Super Glue to hold it together behind that BBF.
Re: C4 leaking
Dang 9.19 a quart. How many quarts these C4s hold?
6jeff6- Posts : 279
Re: C4 leaking
It will depend on your convertor and trans cooler size, but I would think 10 quarts or less.
Re: C4 leaking
I have never used it, but I bet the John Deere and IH fluid is good stuff too.
Re: C4 leaking
That moment when you find out your torque wrench quit working grrrrr! Finally got bolt piece taken out now finally putting it back together.....
6jeff6- Posts : 279
Re: C4 leaking
6jeff6 wrote:I think okay. I've seen merc III, type F and john deere tractor fluid in my searches. Just hoping guys with big blocks say something as the torque is just a tick more
I haven't had a C4 but my C6 I ran type F I have a PG in mine now and I use tractor hydraulic fluid in it
Re: C4 leaking
Broke 2 bolts on pump at separate times of course but got it back together. Went with type F . No leaks so far. Thanks everyone so much for all the help
6jeff6- Posts : 279
Re: C4 leaking
Now my question is do I beat on it and test it or save it for the track because it's a matter of time before it does it again ?
6jeff6- Posts : 279
Re: C4 leaking
I would save it for the track, before something else falls off, and it will.
Re: C4 leaking
Very true I'll put slicks and skinnier on then I'll leave it be
6jeff6- Posts : 279
Re: C4 leaking
Then you have a rear flat in the morning.
» C6 leaking out of bellhousing-All back together and its still leaking!!!
» C6 leaking....
» leaking fluid?
» C&C block leaking
» Nut on reverse brake band adjuster leaking - C6 transmission
» C6 leaking....
» leaking fluid?
» C&C block leaking
Page 2 of 3
