25.1E ------- 64 Fairlane
+45
nitrous.f
Goldylox_fairlane
Bill Heard
wickettoby1
litshoot
rbro460
774 Super Street
drksyde64
ssurles268
pmrphil
D. Sea
514Fox87
Tomasw
maverick532
Wayne Pearce
slurm
AZFairlane
Race Ready Fabrications
larry552
gmsmkr
7.5L1985GT
Mustang-junky
514F-1
whitefield
jeffgfg
QKiss
49 posters
Page 10 of 13
Page 10 of 13 • 1, 2, 3 ... 9, 10, 11, 12, 13
Re: 25.1E ------- 64 Fairlane
SERIOUSLY?
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
Thanks guys for following the build. ----- It keeps me motivated to keep posting.
As for the mini skirt deal.--- With us teasers we figured out it seems like you guys will always come back for another look.
For you guys that would like to help me out with driving chores --- I'm losing track because that list is getting so long.
Believe it or not some of my Cheby buddies said they would like to drive this car that has the distributor on the proper end of the motor.
As far as the debut I was hoping to go to Bakersfield but time is getting away and I need to put a few laps on the car to make sure everything is working right including the driver before I go to a big race like the March meet. --- On the way back from Idaho I picked up the transmission which was the last item to complete all the SFI certs. --- On the reassemble other than just bolting stuff back together there are a few items hanging out on the wiring and the plumbing.
Notice the 3D effect around the head lights where the grill drops back behind them on a stock grill.
The spoiler still needs end caps.
Another detail to notice is that the lettering tapers along with the body feature as it flows to the rear.
QKiss- Posts : 157
Location : Nor Cal -- Fortuna behind the Redwood curtian
man I like this car! it turned out great! good job!
nitrous.f- Posts : 294
nitrous.f wrote:man I like this car! it turned out great! good job!
Thanks --------- But I do think I got a bit carried away with my 10 second car project.
Last edited by QKiss on January 7th 2020, 2:09 am; edited 1 time in total (Reason for editing : spelling)
QKiss- Posts : 157
Can't wait to see this one run!
Spring is getting closer.
68galaxie- Posts : 351
simple to make it a 10 second car, just run the 8th and stop. should pass the quarter marker around 10 seconds while slowing down
litshoot- Posts : 103
QKiss- Posts : 157
I like it
Wicked bad
Mike R- Posts : 1381
What kind of front strut did you use? Car look great.....
Bill Heard- Posts : 115
What is the engine/power combo again?
BBFTorino- Posts : 999
Bill Heard wrote:What kind of front strut did you use? Car look great.....
Bill -- Struts are Strange long travel super stock style ordered from Strange with 5" travel. Early in the build I had the idea of putting a flat tappet cam motor that is setting in the corner in it to drive around on the street at our Autorama week end. Idea was to raise the front end for street driving.
The car is licensed with no-op DMV paper work as it sets. As the project grew up the struts ended up having way to much travel. To put a bandaid on the issue travel limiters were added.
This is what I came up with for a tube style limiter.
Adjustment holes are drilled on 1/2' centers.
The Struts have double adjustable valving that helps prevent wheel standing also.
QKiss- Posts : 157
BBFTorino wrote:What is the engine/power combo again?
.080 over bore --- 4.5 stroke for a 557
The block is a filled 4 bolt main stock block from a drag pack car.
Early fully ported A 460 heads with match ported intake manifold.
Compression is 14to1? -- small bumps on the pistons.
Roller cam is over 800 lift but off the top of my head don't remember duration.
1050 Dominator.
QKiss- Posts : 157
Thank you QKiss……….I have the same issue with two different motors.
nitrous.f wrote:did you dyno the motor?
My engine builder doesn't have a dyno. He uses a computer software dyno that requires a lot of detailed data. His estimate is 915 HP. During the build I took the block to another machine shop to bush the lifter bores that my guy didn't have the equipment to do. I had the Ported A460 heads in the back of the truck with the block. They had just finished and dynoed a 557 with the same heads with flat top pistons that made1000 HP. My engine has a little more compression with dome pistons. I'll dig up the cam specs and post more details on the engine and maybe you guys can give me your thoughts on HP?
QKiss- Posts : 157
OK here are the engine specs. What do you engine guy's think about an honest HP potential for this combination.
557 cu in Finish bore 4.441 stroke 4.500
Block Finish 10.300 Ross Pistons .009 dn Rods 6.700
Heads fully ported early A460 w/77cc chambers 14 to 1 compression
Comp Cam @ .050 duration In 283 Ex 294
Lift In .814 Ex .780
Lobe separation 112
Holley Carb 1050 HP Get 3
Intake manifold - Trick Flow R - Series for A460 Heads match ported with runner clean up.
Headers 2 1/4" S.S. -- 28" Primaries W/3 1/2" Merg collectors
Lobe separation 112
QKiss- Posts : 157
Should be somewhere around 1,000. Mine is very similar with less compression and made 970 on Dyno. Your carb may be a little small though.
stanger68- Posts : 501
stanger68 wrote:Should be somewhere around 1,000. Mine is very similar with less compression and made 970 on Dyno. Your carb may be a little small though.
What size carb are you running? -- My engine builder selected the 1050 with the idea of a stronger broader mid range than a larger carb. Does this translate into the real world?
QKiss- Posts : 157
Put the Fairline on the scales to get an idea what it is going weigh. With no coolant - fuel - hood or wheelie bars and it came in @ 2207 lbs. Was pleasantly surprised considering front fenders are steel. The hood is being made with .040 6061 aluminum so it is not very heavy but it is way to easy to add lbs. Will update with ready to run weight when totally finished.
QKiss- Posts : 157
Mine is running a Ron's Terminator. The build details are in the proven builds under A head 557 I believe. On phone right now waiting at supply house I have to be on computer to tag links. We broke it in on gas 1050 carb before we put alcohol in. It peaked roughly 300 rpm sooner and 50 hp less. Just my humble experience. I'm not a professional builder.
I'm really liking the double track locator....good work!!!
TravisRice- BBF CONTRIBUTOR
Fantastic build!!
I think there will be substantial power increase with a larger carb. I am thinking 1250 to 1350 cfm.
Try what you have - then perhaps borrow a large carb to experiment with.
Will be fun for sure.
Cheers
Cheers
» 64 Fairlane Strut Front Suspension Conversion Its Done! JIT for the bash!
» Finally got to the track
» My 66 Fairlane 472
» 528 in 64 Fairlane
Page 10 of 13
