AFR BBF Head
+49
glenevans
snuff98
jeffgfg
bigford632
Mark Laczo
Straubtech
6t6mustang
STR-LGL-70
The Mad Porter
Mark O'Neal
nickpohlaandp
XF-66
ED468
wayney
Hardy
tbirdmike
68galaxie
Gary Blair
carlthomasd
fastashley
jones
QtrWarrior
Darrin Gorham
Coupe Devil
torino501
Carl
53 posters
Page 2 of 12
Page 2 of 12 • 1, 2, 3, ... 10, 11, 12
Re: AFR BBF Head
Maybe they are trying to make it look like a Rectangle Port BBC to try and get sales LoL.
supervel45- Posts : 4499
Re: AFR BBF Head
supervel45 wrote:Maybe they are trying to make it look like a Rectangle Port BBC to try and get sales LoL.
OR, a low port A460.
Re: AFR BBF Head
AFR makes a good product. Their SBF stuff has done well for years. You get a CNC head, and it only cost a little more. I for one want as many choices as possible. If you're worried about the square port, don't even consider an A460, C460, Profiler, EX514. They're square. Also Awesome.
fastashley- Posts : 70
c 460 heads
I know that some one out there that has had the same problem that I am having . I break bolts in the roller
lifters ever time I take it out. if any one out there can help me out it sure would help me a lot.
my email is carlthomasd@aol.com thanks Carl Thomas
carlthomasd- Posts : 20
Re: AFR BBF Head
I didn't know roller lifters have bolts. Can you clarify on that a little?carlthomasd wrote:I know that some one out there that has had the same problem that I am having . I break bolts in the roller
Scott Foxwell- Posts : 419
c 460 heads
the c 460 heads have 2 bolts that holds the roller rocker in place . they are 5/16 . I break one every time I make a pass. I need some help bad. thanks Carl Thomas
c 460 heads
I am sorry for saying roller lifters I meant roller rockers
Re: AFR BBF Head
carlthomasd wrote:the c 460 heads have 2 bolts that holds the roller rocker in place . they are 5/16 . I break one every time I make a pass. I need some help bad. thanks Carl Thomas
Jesel has an upgrade option to ARP 2000 12 point bolts. I think WW may also.
Re: AFR BBF Head
I'd be looking for coil bind or some other bind in the system. Maybe a geometry issue.carlthomasd wrote:I am sorry for saying roller lifters I meant roller rockers
Re: AFR BBF Head
Scott Foxwell wrote:I'd be looking for coil bind or some other bind in the system. Maybe a geometry issue.carlthomasd wrote:I am sorry for saying roller lifters I meant roller rockers
X2. I'm aware of people breaking the standard hardware but not every pass or even every race.
Re: AFR BBF Head
dfree383 wrote:Comparing a CNC ported head to an as cast head is soooooo fair.
How about a set of full boogie P-51s compared to the Big CNC heads for a fair comparison?
You all have seen several P-51 race engines over 1000hp and I've personally done over 750 on pump gas 466" engines for EMC
How much $ would someone be able to get a set of "full boogie P-51s" for? I understand your point that it's not an apples to apples comparison, but it is an out of the box comparison and the AFR 315s are not much more expensive than an assembled set of P51s. So I'd personally rather see that comparison than one that involves a $5k+ set of P51s
Hardy- Posts : 107
Re: AFR BBF Head
Yes, I know I just bumped an old ass thread. I'm getting close to looking into doing a top half upgrade and been trying find info on the AFR's as to how they stack up against P51's. Just happened to run this thread up in a search
Hardy- Posts : 107
Re: AFR BBF Head
Hardy wrote:Yes, I know I just bumped an old ass thread. I'm getting close to looking into doing a top half upgrade and been trying find info on the AFR's as to how they stack up against P51's. Just happened to run this thread up in a search
I still haven't seen much dyno information to prove out the flow numbers of the AFR's but they sure seem like a cost effective option to the P51 that should make as much or more power.
AP
Re: AFR BBF Head
I did see one guy on Facebook that dynoed his 533 with AFR 315s. Made 830 hp and I think 730 torque. Decent but not anythOmg special. Made good power for the rpm at that ci, though
Hardy- Posts : 107
Re: AFR BBF Head
Hardy wrote:I did see one guy on Facebook that dynoed his 533 with AFR 315s. Made 830 hp and I think 730 torque. Decent but not anythOmg special. Made good power for the rpm at that ci, though
Are you referring to Scotty's build? If so, that wasn't a max effort build.
Re: AFR BBF Head
HorsinAround wrote:Hardy wrote:I did see one guy on Facebook that dynoed his 533 with AFR 315s. Made 830 hp and I think 730 torque. Decent but not anythOmg special. Made good power for the rpm at that ci, though
??? Bryan Parsons posted it on fb. I still think it's pretty good considering the peak torque at 4700 and peak hp at 6900
Hardy- Posts : 107
Re: AFR BBF Head
Not a max effort by any means, not vs. P-51's, but real world non the less.
Outperformed the A429's with 20 degrees less duration and .100 less lift.
http://www.460ford.com/forum/37-engine-tech/238585-afr-528-vs-a429-514-real-world-results.html
Carl- Posts : 284
Re: AFR BBF Head
Hardy wrote:dfree383 wrote:Comparing a CNC ported head to an as cast head is soooooo fair.
What's a port job usually cost you for a set of aluminum heads? It's no $3000 here.
You don't need much grinding to get a lot better numbers on the p-51 heads
Re: AFR BBF Head
Carl wrote:Not a max effort by any means, not vs. P-51's, but real world non the less.
Nice slanted comparison...... pocket ported copy of a factory iron head vs a CNC ported AFR head with an extra .15 stroke, that's real world salesmanship.....
Re: AFR BBF Head
dfree383 wrote:Carl wrote:Not a max effort by any means, not vs. P-51's, but real world non the less.
Dave you know I'm no expert so I'm going to ask a couple dumbazz questions. 1. would the extra 14 cubes make that much difference? 2. the 514 had a 244/252 .608/.633 118LS solid flat tappet, and the 528 had a 224/234 .538/.562 112LS hyd flat tappet cam. Is this cam a little small for the 270 head? If so then I can't help but wonder what times he could have posted if he had used a cam suited to the head.
Re: AFR BBF Head
dfree383 wrote:Hardy wrote:dfree383 wrote:Comparing a CNC ported head to an as cast head is soooooo fair.
Gotcha. I took full boogie to mean max effort, 2.30 intake valve, etc. Obviously a typical port/valve job wouldn't be $2500 over the as cast, assembled price from Kaase. And I'm not trying to argue against the P51s at all. If i were making a purchase today, I'd go with them because it is known what they are capable of and they should meet my short term goals, easily. I'm just interested in seeing how theAFRs do in comparable builds because I still have some time before I have to decide.
Hardy- Posts : 107
Re: AFR BBF Head
[quote=defree
[/quote]
several NO.
2 , after the heads been around for 10 years , Not what I'd call great.
[/quote]
several NO.
BOSS 429- Posts : 2372
Re: AFR BBF Head
I said it over there ,and Ill say it here, not a real world deal with neither eng has the same bore,or stroke.
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» the best head
» P51 Head HP gain after head port
» the best head
Page 2 of 12
