AFR BBF Head
+49
glenevans
snuff98
jeffgfg
bigford632
Mark Laczo
Straubtech
6t6mustang
STR-LGL-70
The Mad Porter
Mark O'Neal
nickpohlaandp
XF-66
ED468
wayney
Hardy
tbirdmike
68galaxie
Gary Blair
carlthomasd
fastashley
jones
QtrWarrior
Darrin Gorham
Coupe Devil
torino501
Carl
53 posters
Page 12 of 12
Page 12 of 12 • 1, 2, 3 ... 10, 11, 12
Re: AFR BBF Head
What push rods do you recommend? AFR recommends 3/8" thick wall, and my cam will be an .819 lift, so I want to get the best set possible to limit side deflection and good tips.
Re: AFR BBF Head
HorsinAround wrote:What push rods do you recommend? AFR recommends 3/8" thick wall, and my cam will be an .819 lift, so I want to get the best set possible to limit side deflection and good tips.
Depends on the cam and valve springs used.
.135" wall x 3/8" are used in many applications.
Re: AFR BBF Head
Lem Evans wrote:HorsinAround wrote:What push rods do you recommend? AFR recommends 3/8" thick wall, and my cam will be an .819 lift, so I want to get the best set possible to limit side deflection and good tips.
Gotcha. As I mentioned the max cam lift is .819 (I'll have to look at the cam card when I get home to get all the specs) and I am using the PAC Racing #1224 1.625" OD Solid Roller Dual Valve Spring 275 lbs. on seat, .850" maximum lift.
I have always used Comp push tubes, but did have trouble with a tip collapsing usually once or twice a season on the pulling truck and the lift wasn't quite as big. Also this is a 533 drag motor build, so it won't see the rpm that the puller saw...
Re: AFR BBF Head
HorsinAround wrote:Lem Evans wrote:HorsinAround wrote:What push rods do you recommend? AFR recommends 3/8" thick wall, and my cam will be an .819 lift, so I want to get the best set possible to limit side deflection and good tips.
I get our rods from the same place Comp does only cheaper.
AFR 598 build
BOSS 429 wrote:BBFTorino wrote:So let me try to get this right....and correct me if Im wrong.
The AFR heads are a quality product, and they are better 'out of the box' than a P-51 or SCJ head, yes?
But with some porting, the P-51 and SCJ's would make more power than the AFR's, yes?
But with further porting on the AFR's, they would out perform the P-51 and SCJ's, yes?
Has anyone done any custom porting on a set of AFR's yet??....I mean like somewhat beyond the out of the box CNC job that they already have??
If so, it would be interesting to see the comparison of the CNC version against a hand ported version.
As I understand it, a set of P-51 or SCJ heads still needs the intake to be ported/matched to the heads (if one wants to optimize their combo), but the AFR intake matches the AFR heads a lot better right out of the box, yes?
YES, HAD A SET OF THESE HEADS in my hand today, I hope I get to work on a set.keep in mined THEY come ported from AFR.
Gary Blair- Posts : 221
AFR 598 build 1100 HP
Mike Stark built an 1100 HP 598 with AFR heads. He did some hand porting on the heads. He also did some plenum modifications. It has 14-1 compression and used Q-16 gas.
Look at Oakley's build. Pretty much out of the box heads and manifold. Impressive. AFR says there are some upgrades on the way as well.
Last edited by Gary Blair on February 16th 2022, 10:57 pm; edited 2 times in total (Reason for editing : left out a detail)
68formalGT likes this post
Re: AFR BBF Head
Gary Blair wrote:Mike Stark built an 1100 HP 598 with AFR heads. He did some hand porting on the heads. He also did some plenum modifications. It has 14-1 compression and used Q-16 gas.
Yeah they have some catching up to do…….
![:joy: 😂](https://cdn.jsdelivr.net/emojione/assets/png/1f602.png?v=2.2.7)
Re: AFR BBF Head
dfree383 wrote:Gary Blair wrote:Mike Stark built an 1100 HP 598 with AFR heads. He did some hand porting on the heads. He also did some plenum modifications. It has 14-1 compression and used Q-16 gas.
Mike Stark, Oakley, or AFR needs to catch up?
68formalGT- Posts : 865
Mark Miller and Gary Blair like this post
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» Another C-head?
» P51 Head HP gain after head port
» Another C-head?
Page 12 of 12
