AFR BBF Head
+49
glenevans
snuff98
jeffgfg
bigford632
Mark Laczo
Straubtech
6t6mustang
STR-LGL-70
The Mad Porter
Mark O'Neal
nickpohlaandp
XF-66
ED468
wayney
Hardy
tbirdmike
68galaxie
Gary Blair
carlthomasd
fastashley
jones
QtrWarrior
Darrin Gorham
Coupe Devil
torino501
Carl
53 posters
Page 3 of 12
Page 3 of 12 • 1, 2, 3, 4 ... 10, 11, 12
Re: AFR BBF Head
Waiting on Lem and Oakley's max effort build results!
68formalGT- Posts : 865
Re: AFR BBF Head
Carl wrote:The engine appears to be the same configuration as used in the previous article were the 270's made 75HP more than unported SCJ's.
"The 10.0:1 M-6007-521FT crate motor featured a stroker crank, forged pistons and rods, and a solid roller cam. ... the cam in the crate motor was upgraded to a healthier grind sporting a 0.780 lift (intake and exhaust), a 275/284-degree duration split, and a 110-degree (+5) lsa. Additional featured of the test motor included a Victor single-plane intake designed to accept a 4500 (Holley Dominator) carb, an MSD distributor, and a front-sump oil pan. For the initial test, the 521 crate motor was equipped with the as-supplied aluminum Super Cobra Jet heads. The Super CJs featured 290-cc intake ports, 72-cc combustion chambers, and a 2.20/1.76 valve combo.
The test procedure was simple: Run the modified 521 first with the Super Cobra Jet heads then again with the new AFR 270s (with 72cc chambers). To ensure adequate airflow, the testing included a 1050 Holley Ultra Dominator carb. Equipped with the Super Cobra Jet heads and Edelbrock intake, the cammed 521 produced 652 hp at 6,500 rpm and 649 lb-ft of torque at 4,700 rpm. After the installation of the new AFR 270 heads, the peak numbers skyrocketed to 727 hp at 6,400 rpm and 674 lb-ft of torque at 5,000 rpm. Note that not only did the extra intake and exhaust flow offer more peak power (as expected) but the efficiency of the new design (bigger flow through a smaller hole) offered power gains through the entire rev range. "
From all appearances, it was a pretty straight forward test. The cam used isn't a whole lot different than Kaase's spec cam for the P51's (273/280 degrees duration, 0.791/0.787-inch lift, and a 109-degree lobe-separation angle) used in this test: http://www.hotrod.com/articles/hemi-vs-wedge-shootout-jon-kaase-settles-one-of-the-most-fiercely-debated-topics-all-time-with-ultimate-dyno-test/ .
If anyone feels it was unfairly biased, maybe they should do their own test, instead of calling the people who actually put in the work on this one liars.
Interesting that nobody is questioning the Trickflow's performance.
Interesting P-51 vs. TFS. If I recall correctly Blake Cartwright has gone some 5.60's on motor with the TFS.
Gary Blair- Posts : 221
Re: AFR BBF Head
BOSS 429 wrote:[quote=defree
You all have seen several P-51 race engines over 1000hp
several NO.
2 , after the heads been around for 10 years , Not what I'd call great.[/quote]
Very true. 2 at 1000 HP. Be interesting to know if there are others,
Re: AFR BBF Head
Gary, do you think when people are looking at making 4 digit horsepower they are usually steered towards A460 or C460 heads and that's why we don't see many proven 1000 hp P-51builds?
Re: AFR BBF Head
68formalGT wrote:Gary, do you think when people are looking at making 4 digit horsepower they are usually steered towards A460 or C460 heads and that's why we don't see many proven 1000 hp P-51builds?
Makes sense Joe. More potential for future growth.
Re: AFR BBF Head
Interesting "truthful" dyno testing.
The camshaft was very similar to the one used in the test Kaase did (comparing P51 to hemi).
In that test with a 521 cu inch platform Kaase gets 801 HP at 6700 rpm. (273/280 @ 0.050" 0.791" on 109 LSA 10:1 CR)
The AFR test shows a 521 engine with P51 heads just touched 700 hp. (275/285 @ 0.050 0.780" on 110 LSA 10:1 CR)
What gives?
The P51 seems 100 HP down from the Kaase test to the AFR test.
I find it hard to beliece a 521 with P51 heads and a resaonably large solid roller camshaft would only touch 700 HP.
Someone is full of something here.
Just my humble opinion.
Who am I to argue with AFR published test data?
But something smells fishy
What gives?
68galaxie- Posts : 351
Re: AFR BBF Head
I would also add that typically the heads up racers set the trends that trickle down to the budget minded bracket racers and test n tuners. With the majority of big block, heads up stuff allowing A460s, the development of the P51s hasn't reached its peak probably..... and I don't see high end used P51 parts out there like I do A460 stuff.
Hardy- Posts : 107
Re: AFR BBF Head
68galaxie wrote:Interesting "truthful" dyno testing.
What gives?
Lol. Wow, good catch. Restrictor plate???
Hardy- Posts : 107
Re: AFR BBF Head
That's clearly the case. Most people don't have a 1,000 hp budget and those that do mostly go to A460 heads.
Re: AFR BBF Head
Lem Evans wrote:68formalGT wrote:Gary, do you think when people are looking at making 4 digit horsepower they are usually steered towards A460 or C460 heads and that's why we don't see many proven 1000 hp P-51builds?
Or class restrictions like factory intake and exhaust manifold bolt patterns.
Re: AFR BBF Head
great info.
Seeing the peak rpm hp on good heads and large cam. Then constantly seeing fools saying there stock rotaters rev 7000, yet dont have more the 250-260@050 cams with dove heads. I just shake my head knowing that they are done well before 7000.
tbirdmike- Posts : 34
Re: AFR BBF Head
What gives?
This is why you can't race dynos. Different conditions, different correction factors, etc.
At the end of the day, the AFR test was done on the same dyno, on the same engine, by the same dyno operator, under the same conditions. If you think Westech Performance and Steve Brule are going to jeopardize their hard earned reputation by allowing somebody to perform a bogus test and publish it with their name on it....well, maybe you've had a little too much Kool-aid.
Carl- Posts : 284
Doxnoogle likes this post
Re: AFR BBF Head
When I stopped by Oakley's last October, he had a set of AFR 325's on the shelf for a customer. Does anyone know how they did?
Also, when I talked to Racetec about pistons for a 75cc ARF325, they said the design only allowed for 15:1 comp. Does anyone know if pistons can be had with higher compression?
Re: AFR BBF Head
Sorry to say Carl - you are the one drinking the AFR coolaid - and promoting the AFR products.
I have no "skin in the game" that you clearly have.
How do you explain a 521 P51 headed engine with a reasonably large solid roller cam falling on its face barely making 700 HP?
You can't.
I believe most here can separate very slanted advertising or "testing" vs. real world results.
Re: AFR BBF Head
Carl, I found an AFR test of their 270 CC head vs a SCJ head on a Ford 521 crate short block. I think the cam was a 275/285 @ .050 etc etc. The AFR 270 made 722 HP I think. Were all these other results that you posted from the same day and test at Westech? I posted a link on the Bullet a few months back.
Re: AFR BBF Head
You can't.
There is no P-51 slant?
Re: AFR BBF Head
Lem whats up with P-51 availability? When will they return? Are they done?
Re: AFR BBF Head
Gary Blair wrote:Carl, I found an AFR test of their 270 CC head vs a SCJ head on a Ford 521 crate short block. I think the cam was a 275/285 @ .050 etc etc. The AFR 270 made 722 HP I think. Were all these other results that you posted from the same day and test at Westech? I posted a link on the Bullet a few months back.
I wasn't there. Pretty sure Tony Mamo ran the whole deal. Maybe give him a call. He's running his own deal now, and no longer with AFR.
https://www.mamomotorsports.com/
Carl- Posts : 284
Re: AFR BBF Head
Come on Gary B,
You really think a 521 BBF with P-51 heads and a 275/285 solid roller will make no more than 700 HP peak?
Maybe the Kaase test was faked or exaggerated? By how much in your opinion?
You believe the AFR head is 75 HP better than the P51?
Good grief if these AFR heads are 75 hp better than a P51 head it should be a piece of cake to get to 1100 hp.
Re: AFR BBF Head
68galaxie wrote:Sorry to say Carl - you are the one drinking the AFR coolaid - and promoting the AFR products.
You can't.
Skin in the game? I have no sales quota to meet with AFR, and the margins on their heads are paper thin. Frankly I couldn't care less what heads people use. I'm happy to supply whatever parts people want, but after building several engines with the AFR heads, I've found that dollar for dollar they're just flat the best stock style head available. No extra added rubbing needed, no never ending wait lists, just bolt-em on and go. If I were really interested in pumping people for max profit, I'd be pushing the heads that need extra work to make them right.
Have you even seen the AFR's in person, let alone built an engine with them, or done any testing on them? Maybe you should do your own testing before calling other people liars and cheats.
Carl- Posts : 284
Re: AFR BBF Head
68galaxie wrote:Come on Gary B,
You believe the AFR head is 75 HP better than the P51?o
This series of tests were done on a 10-1 FRPP 521 short block. JK's and SAM's 521 was closer to 11.3-1 compression.
Not sure on the HP difference yet. Going to study it more for sure. JK is a master engine builder. He is a master at the subtleties as well. You have to pay close attention . The AFR 285 is CNC finished. Is the P-51 as cast? The JK and SAMS 521 has ported P-51's. Just saying. Ported P-51's and CNC 315 AFR's @ 11.3 compression for both would be interesting. I'd like to see how both light up the scoreboard instead of racing dyno's.
AFR/SCJ test
http://www.mustangandfords.com/how-to/engine/1505-big-block-chevys-beware-afr-270-bbf-cylinder-head-test/ This is the AFR 270 vs an as cast SCJ article.
Re: AFR BBF Head
http://www.popularhotrodding.com/tech/0906phr_big_block_ford_engine/index.html SAMS/JK 521 P-51 build and dyno test.
Re: AFR BBF Head
Just to make everyone remember that all these heads were created to perform well in DIFFERENT situations.
The SCJ Ford Racing head was a STREET high performance head which COULD be used on a mild race engine. It was MEANT to be the best with a valve lift around only .700" or less; more lift does not help much on them. AND, to me, the P-51 is simply a glorified SCJ.
It is very difficult to make any comparison of all these heads when they all perform best within their own realm and not so good in others.
Re: AFR BBF Head
If anyone would be interested in setting up a dyno session to do our own comparison, I can offer a brand new set of AFR 315's and intake.
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» the best head
» P51 Head HP gain after head port
» the best head
Page 3 of 12
