BBF oil pump question
BBF oil pump question Empty BBF oil pump question
Post  gowie December 22nd 2009, 11:47 pm
What is the height difference between a rear sump oil pump & a front sump oil pump. I believe the front sump pump is taller, but I'm not sure by how much. Thanks
gowie
BBF oil pump question Empty Re: BBF oil pump question
Post  chuck stevens December 22nd 2009, 11:51 pm
The PUMPS are the same...the pickups are what's different.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  Greg_P December 23rd 2009, 12:21 am
Ever try to bolt a front sump pickup onto a rear sump pump? Mad
The rear sump pump 'looks' shorter, but I've never actually had them side by side.
Greg_P
Greg_P
Post  chuck stevens December 23rd 2009, 12:39 pm
Only if you're looking at a truck pump.
chuck stevens
Post  Paul Kane December 24th 2009, 3:02 pm
gowie wrote:What is the height difference between a rear sump oil pump & a front sump oil pump. I believe the front sump pump is taller, but I'm not sure by how much. Thanks
Assuming both front and rear pumps in question are either high volume or standard volume, then the overall heights between the pumps are the same. It's the mounting point of the pickup tube's flange that is at a different height betwen the F & R pump styles.
Paul
