Casting flaws in D1VE 429/460 block?
Re: Casting flaws in D1VE 429/460 block?
A up bud , on here before me ! i'm 57ford haha .
57ford- Posts : 8
They won't matter at all ... most every block has little flaws, just that most are not exposed by machined surfaces.
Common casting flaw. Where they are located, is fine. You can mix up some JB Weld epoxy and fill it in and file it flush with the deck surface. It will be just fine.
BBFTorino- Posts : 997
deck flaws
looks like you might have a leak around the stiffening rod. Not a real problem though! Fixed hundreds of these over the years. Use bronze rod to braze (fill in) all of the flaws. Then have it skim surfaced. This is the proper way to repair these minor, non crack related flaws!
jmarks99- Posts : 6
jmarks99 wrote:looks like you might have a leak around the stiffening rod. Not a real problem though! Fixed hundreds of these over the years. Use bronze rod to braze (fill in) all of the flaws. Then have it skim surfaced. This is the proper way to repair these minor, non crack related flaws!
Can you get the block hot enough for the bronze to flow and adhere properly?
57pickupUK- Posts : 4
Can you get the block hot enough for the bronze to flow and adhere properly? [/quote]
block doesn't need to be preheated, but it might help. just make sure you use flux powder.
jmarks99- Posts : 6
» D9 or d1ve block
» D1ve block and cj caps
» Value of 1971 D1VE block
» will tfs A460 heads work on my d1ve block ? or do they only work on the race blocks
» 302 block casting #??????
