D9 or d1ve block
D9 or d1ve block Empty D9 or d1ve block
Post  Steve-oh March 15th 2020, 9:37 pm
Building a 557 with mahle pistons, know the d 9 block has deeper walls, and possibly may have to clearance , any pro or cons to one or the other?
Steve-oh
D9 or d1ve block Empty Re: D9 or d1ve block
Post  Lem Evans March 15th 2020, 11:10 pm
No clearance issues either with either block
Post  rmcomprandy March 16th 2020, 10:23 am
Steve-oh wrote:Building a 557 with mahle pistons,  know the d 9 block has deeper walls, and possibly may have to clearance  , any pro or cons to one or the other?
Use the longer bore with that stroke ... an A460 block would be my choice.
Post  69F100 March 16th 2020, 11:52 am
I am running a 552 4.5 stroke and d9 block I didn't have to clearance the cylinder walls.
Post  Steve-oh March 16th 2020, 12:10 pm
Been looking at blocks too, was told the factory ones will be fine to the 800-850 mark
Steve-oh
Post  Steve-oh March 16th 2020, 12:13 pm
How hard are you turning it? Street engine?
I thought about possibly filling to bottom of water pump holes, I'm running methanol as well.
Steve-oh
Post  Paul Kane March 16th 2020, 1:32 pm
i would evaluate both blocks then select the one better suited overall (ie, cylinder wall thickness & uniformity, core shift, etc).
Post  Steve-oh March 16th 2020, 1:54 pm
Paul I was checking out your site, going to do your mods to the block of I decide to use a factory block, what's the difference between your pump and the kasse pump and what kind of clearances do you like to see on the bottom end?
Steve-oh
Post  Paul Kane March 16th 2020, 6:57 pm
Give me a call at the shop and I'll be happy to discuss your current build and make some recommendations.
Post  69F100 March 16th 2020, 7:44 pm
[quote="Steve-oh"]
I thought about possibly filling to bottom of water pump holes, I'm running methanol  as well.[/quote.
I turn it to 7000 rpm on the top end shift at 6500 mine is not filled I run methanol with a Ron's tolit
