Arias piston
Arias piston
Arias used to offer a "shelf" dome piston for standard iron heads.
Anybody know what kind of CC the dome was on these?
I apologize I do not have a part number
EverySparePenny- Posts : 114
Re: Arias piston
EverySparePenny wrote:Arias used to offer a "shelf" dome piston for standard iron heads.
A couple years ago I got some "shelf" SBC pistons from them for a 4.030" bore having a 1.250" compression height which had 11.5 cc domes. A big block Ford would probably be close to that.
They were Arias pistons in the "600" kit which Ford Motorsport offered in the late 90's.
Re: Arias piston
Call CP. They should be able to accommodate you.
Mark O'Neal- Posts : 286
Re: Arias piston
Thank you gentlemen.
With way to much time on google I was able to locate an old Arias catalog. They list the dome at 10cc
Re: Arias piston
I believe CP bought Arias for the sport compact business . I don't think they are making any of the V8 stuff Arias used to make.
gt350hr- Posts : 662
Re: Arias piston
gt350hr wrote: I believe CP bought Arias for the sport compact business . I don't think they are making any of the V8 stuff Arias used to make.
I believe you are correct.
I ran across a used set of them to use in a budget throw together deal and trying to get an idea if I can get enough compression in the engine to make due. I think we'll be good to go if it's close to that 10cc advertisement.
Re: Arias piston
I had a set of those. I cc'd them and they were 11.5cc
466CI, fel-pro 1018, 77cc chambers averaged 13.4
compression.
compression.
DGS- Posts : 12
Re: Arias piston
Perfect! I should be able to get where I want to be with 66cc Chambers then
Re: Arias piston
They should still have all the engineering data what went with the company.
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
» compression ?
» P51 466 piston
» Piston
» 429 or 460 piston
» compression ?
» P51 466 piston
» Piston
» 429 or 460 piston
