New 598 build, mud racing
+6
norm
wickettoby1
2 wicked
10 posters
Page 3 of 4 Previous  1, 2, 3, 4  Next
New 598 build, mud racing - Page 3 Empty Re: New 598 build, mud racing
Post  norm August 23rd 2022, 8:17 pm
Ok when you said a "trickle" of oil it had me concerned.
I have a .080" hole in the front and rear is plugged, like yours. BAM lifters i had to groove a bit but mine oils way more than a trickle. T&D's also.
Maybe it's the "restricted" push rods you have. Mine are 7/16 .165 wall Trends but not a restricted push rod.
It's amazing how much oil flows through that .080" hole. I prime with the intake off and oil pours out the the roller on the lifter
norm
norm
Post  2 wicked August 23rd 2022, 9:14 pm
Yes, the pushrods have a .040 restriction. Eliminator recommended a.125 restrictor in the gallery, tried that, to much oil, went to .060 restrictor and thought it might not be enough. So I ended up at .100. and yes I had a lot of oil coming out as round the lifter wheel. I look at it like this, oil is blood to a engine. Rather loose as little power to windage than starve valvetrain of oil. Thanks cory
2 wicked
Post  norm August 24th 2022, 7:06 pm
I agree. I want it to live, not worried about the power difference. Won't notice that in a 5300lb truck anyway
norm
norm
Post  2 wicked August 24th 2022, 7:57 pm
Norm, I should clarify what I consider a trickle. Oil was running off each rocker nose - wheel. Way less than a stock engine. We primed for probably 5/6 minutes. Never over oiled, the drain back holes in heads never backed up with oil. Bought the same as our 557. Thanks cory
2 wicked
Post  2 wicked September 6th 2022, 6:58 pm
After I inspected trans issues, I worked on the engine. Got the intake on. Ports lined up perfect. Figured I would have to massage them a little. Only things left are rear cam tunnel plug and install all the screw in freeze plugs then mask of the block and give it a shot of paint. Thanks cory
2 wicked
Post  2 wicked December 14th 2022, 8:59 pm
Well, got the engine bolted in the chassis. With the taller intake, had to make new fuel lines. Reconfigure the accessory drive setup. Now have alt,fuel pump,power steering pump, vac pump to mount. It was a pain to get it laid out. But its finally ready to fire up. Had one problem with carb, the secondary float bowl was leaking. Found the fuel inlet threads were almost stripped. Swapped the bowls off the 1150 and was good to go. Plan on firing it up this weekend.
2 wicked
Mark Miller and John Myrick like this post
Post  2 wicked December 15th 2022, 5:22 pm
Hey all, my son was chomping at the bit to fire it up today. I gave him the option, go deer hunting or go fire it up. Guess which one he chose, lol. We put a heat lamp under the pan for about 2 hrs while we double checked wiring, nuts n bolts. Filled up with water, primed fuel system etc. Fired up almost instantly. Wish I was good at computer shit I would of posted up picks and a video, lol. Set the timing at 28 locked out. Hardly had to do much adjustments to the carb. It was very close, idle mix was enriched about 1/2 turn out and rear butterfly about 1 turn open. Idle cleanly at 1300 rpm. Brought up to about 180 temp for 10/15 min. Oil pressure hot was 45 at idle and 75 just off idle. Idled smoother than the 557. But boy does it have throttle response. Just touch the throttle and instantly 5000 rpm. Never dreamed it would be that responsive. I will try to get my son to post up some pics n video. Would like to say thanks to Lem Evans, Mike Jones, Patrick from Prosystems. And all the people on this sight. And a good friend of mine Steve. Without all of you probably still be running the old setup this coming race season. Thanks cory
2 wicked
J.Toney and Mark Miller like this post
Post  2 wicked January 5th 2023, 8:56 pm
Hey all, got through holidays In one piece! 😆. Started adding up parts list for the transmission. Ended up only 400$ from what a fully built C6 from Broader performance cost. So I called them up today and ordered a C6 fully rollerized, trans brake, 300m input shaft and a 10" 5500 stall convertor. Jay said it will be about 8 weeks. I have bought parts from him in the past. Excellent guy to deal with.
2 wicked
Post  2 wicked February 11th 2023, 4:42 pm
New 598 build, mud racing - Page 3 Img_2010
2 wicked
Post  2 wicked February 11th 2023, 4:43 pm
Finally figured out how to post pics!!! 😆
2 wicked
Post  2 wicked February 11th 2023, 4:46 pm
2 wicked
Post  2 wicked February 11th 2023, 4:47 pm
New 598 build, mud racing - Page 3 Img_2011
2 wicked
Post  2 wicked February 11th 2023, 4:48 pm
New 598 build, mud racing - Page 3 Img_2012
2 wicked
J.Toney likes this post
Post  2 wicked February 11th 2023, 4:51 pm
Got to revamp some mounting brackets for the alternator. Hopefully the new midplate from KFM shows up, and then the trans and convertor in a couple weeks. Thanks cory
2 wicked
Post  norm February 11th 2023, 9:40 pm
Looks good
norm
norm
Post  BBFTorino February 13th 2023, 4:34 pm
That engine would be sweet in that Camaro! LOL
Post  2 wicked February 13th 2023, 7:49 pm
The Z28 is my buddies wife's car. It's getting a big block but the wrong flavor!!!!! Lol 😆
2 wicked
Post  2 wicked April 18th 2023, 10:20 am
Got a few more pieces n parts ordered yesterday. Yukon pro N center section 3.25 bearing, 35 spline spool, 1350 billet yoke, and 9310 big pinion pro gears-3.89 ratio, and billet Daytona pinion support. Ordered from Quick performance, they had everything in stock!!!!, Never dreamed they would have the gears in stock, ships today. One more piece to the puzzle.
2 wicked
Post  norm April 18th 2023, 8:36 pm
2 wicked wrote:Ordered from Quick performance, they had everything in stock!!!!, Never dreamed they would have the gears in stock, ships today. One more piece to the puzzle.
They are a good company to deal with.
norm
norm
Post  2 wicked April 30th 2023, 2:36 pm
Well, I got the new rear diff done. Had a hell of a time getting a good pattern. Must of had the pinion out 15 times. Get the pattern centered but would be to high on ring gear tooth. Ended up moving pinion in .005 and opening lash to .011/.012 to get a decent pattern. I have done probably 25 9" diffs and this was the absolute worst to get a decent pattern. Thanks cory
2 wicked
Post  norm April 30th 2023, 2:58 pm
What brand gears are they?
norm
norm
Post  2 wicked April 30th 2023, 5:55 pm
Motive 9310 big pinion - 3.89 ratio.
2 wicked
Post  2 wicked May 13th 2023, 7:53 am
More pieces n parts showed up the other day. Transmission and convertor from Broader performance. Gave them all the specs on the engine and truck. Got a 10" 5500 convertor, after a little thought I should have told them to shoot for 58/6000 stall. If it ends up tight I will send it back for restall. Jay at broader perf is a great guy to deal with and a straight shooter.
2 wicked
Post  2 wicked June 19th 2023, 11:22 am
Got the new rear driveshaft ordered today, 4" tube, 1350 solid joints. Forged yokes and spline stub. Thought the price was fair, 650$
Now the axles need to get ordered, 35 spline from quick perf. Thanks cory
2 wicked
Post  2 wicked July 12th 2023, 10:45 am
Well trying to make progress, axles showed up the other day. 35 spline 3" wheel studs from quick perf. And stupid me thought I would install them and get the rear end buttoned up. Not the easiest with my shoulder all banged up. I hurt like hell yesterday. Should've waited for my son to get there. But now have to slide trans back and replace flex plate. Want to try less start retard. Bad idea, kicked back and took a tooth off. So that's this weekends project. Trying to make it to a race in 2 weeks. Still got some tuning to do.
2 wicked
