1969 Galaxie 500 - high school/college kid budget build
+8
Falcon67
1982GT
12 posters
Page 5 of 5
Page 5 of 5 • 1, 2, 3, 4, 5
Re: 1969 Galaxie 500 - high school/college kid budget build
Yeah and we don't get out there near often enough.
It's only 12 miles from my house.
BigBlockRanger- Posts : 1261
BigBlockRanger wrote:Yeah and we don't get out there near often enough.
That would be nice the closest track to my house is probably 40 miles away!!Far enough that i wouldn't want to drive the Mustang!!Now if it was only 12 miles away i would have no problems driving the Mustang to the track!!
Mark Miller- Posts : 1948
While this is still my son's project car, I have to do some behind the scenes work on it. He is away at school and is unable to work on it, so I try to do stuff to facilitate progress when he is home.
I started messing with the E4OD we hope to put in this car. This particular one does not have a provision for a speedo drive or output speed sensor.
I popped the tailshaft housing off to see if I could come up with a way to retrofit a reluctor wheel of some sort.
While I had the tail shaft housing off I noticed that the parking pawl does not have a return spring. I always knew this transmission had a rattling noise in it but I thought it was in the torque converter. I only heard it when I was decelerating. I'm glad it never decided to put itself in park while I was moving!!
I designed a reluctor wheel for it and printed it out with my 3D printer. If it fits as expected I'll have send cut send cut one out of steel.
I elected the drill a new hole just below the speedo drive to mount the sensor. The speedo drive hole was just too high compared to the center line of the output shaft.
I drilled a half inch hole and it's almost aimed directly at the shaft center line. Then I took some aluminum and made a plate that will support the sensor. I still have to come up with a way to seal it, but I don't think that'll be a big deal.
» off to high school now!
» 352 FE 1962 Ford Donated High School Auto Shop Engine
» low budget 460 build up
» need help budget build 460
» Budget 466 build, hp guesstimate.
Page 5 of 5
