1969 Galaxie 500 - high school/college kid budget build
Page 3 of 5 • 1, 2, 3, 4, 5
Re: 1969 Galaxie 500 - high school/college kid budget build
Be very careful of those drop base air filters....I've seen too many instances where the throttle gets stuck wide open under the drop base, and cannot return, even with dual return springs!BigBlockRanger wrote:He wanted to use the HEI distributor (for simplicity) and it is a tall sucker. He put a 2" spacer under the car and a flat base air filter to clear the distributor. We might be able to wiggle stuff around and get a shorter spacer and a drop base in there. We didn't think it would be an issue, but it doesn't have to have a hood to start up and drive!
You need to check for clearance when opening and closing the throttle.
BBFTorino- Posts : 999
BigBlockRanger and Mark Miller like this post
BigBlockRanger- Posts : 1267
Disaster. Lower hose showed up and it is not correct. I figured it out though. For some reason everyone shows the part number for the hose that fits a tbird or Mark 3 that use the shorty water pump. The outlet on those point to the 3 oclock position, whereas a normal BBF pump points to more like a 4:30 position. The hoses are scarce, but I ordered the correct one from Jegs. Fingers crossed.
69F100 and Mark Miller like this post
BigBlockRanger wrote:Upper hose fit great. Judd welded up a new battery box because the stock battery area is pretty much gone.
FWIW i've had the best luck getting the right radiator hoses for the 429-460 engines at Oreillys Auto Parts!!
Mark Miller- Posts : 1957
BigBlockRanger likes this post
Mark Miller and 1982GT like this post
BigBlockRanger wrote:It works. Carb is a bit wonky. I think the rear float is stuck because fuel is coming out of the booster all the time.
https://youtu.be/c-U1zKWNINA
Sounds pretty good and the best part is the smile on your sons face when it fired up!! What cam did you end up going with?
hbstang likes this post
Judd picked a Lunati Voodoo 10340704
Hyd Flat Tappet
233/244 @ 50
.564/.582
110 LSA
BigBlockRanger wrote:Yeah, I wanted to make sure I got his face in the vid.
Hyd Flat Tappet
233/244 @ 50
.564/.582
110 LSA
It would be great to see this at the Big Block Ford Reunion Race in Paducah.
Hyd Flat Tappet
233/244 @ 50
.564/.582
110 LSA
4.11 Gears right?Sounds like that cam will need a Stall Converter For Sure!!
Hood fits, doesn't get hot, oil pressure is good, new front wheels and tires on!
Good times with Judd!! No burnout because the rear tires are suuuuper duper sketchy and because I think the trans is low on fluid.
Need to monkey with the carb a little, check trans fluid and adjust brakes.
t-bird racer- Posts : 193
BigBlockRanger, 69F100 and Mark Miller like this post
I was worried about the trans and converter, but they really worked great! Car was cutting 2.00 60 foot times. I was pretty happy with that considering this thing prob weighs 4200 at the line.
Man, this car is rad.
https://youtu.be/uL3tIBgRO0s
I know he is a very happy young man
BigBlockRanger wrote:This car was last on the road in 2002. One year before Judd was born. Last night it made it's first passes down a dragstrip. We fought issues with carb and ignition all evening but we had a blast anyway. Judd worked his butt off on this thing and it was good to get to finally enjoy it.
Very Very Cool i know the car was breaking up but what were the best times?
BigBlockRanger wrote:That was him breaking up. He monkeyed with it and never got it to make a clean pass. He didn't care though. He was just happy to be there with a car he bought 6 months ago and worked so hard on.
It sounded like not enough amperage getting to the ignition.
This was his only chance to tnt it before he leaves for USAFA. I have some other ignition options we may try out.
I wanted to use that HEI because it was proven and I was 99.9% sure it would fire right off when we were breaking in the cam. We might ditch it and go with a more traditional Ford setup. We have plenty of time to fiddle with that now. Once sorted I think it will run really good.
Also I can't BELIEVE the trans works as good as it does. It was disgusting on the outside and I am not sure it has ever been rebuilt. It was in the F250 when I bought it. We just opened it up and Judd put a shift improver kit in it and crossed our fingers. Haha.
BigBlockRanger wrote:He never made a full pass. The first pass was a 15.88 but he backed off as soon as it started popping and just motored on to the finish. It went downhill from there. Haha. Add to it being 95 degrees and our DA is usually 6000+ feet here.
The H.E.I. does work when using an ignition 20A relay using full battery power to the ignition with a #12 or larger wire.
I say that because I have been there with a customer vehicle.
Part throttle does not need near as much amperage as under a load at higher RPM full throttle.
The current setup is power off an underhood fuse block that we added, to a heavy duty toggle switch and then out to the distributor. Judd wanted it simple so we made it simple. Haha.
» 352 FE 1962 Ford Donated High School Auto Shop Engine
» low budget 460 build up
» need help budget build 460
» Budget build questions
