1969 Galaxie 500 - high school/college kid budget build
Page 2 of 5 • 1, 2, 3, 4, 5
BigBlockRanger- Posts : 1267
Re: 1969 Galaxie 500 - high school/college kid budget build
Mark Miller and John Myrick like this post
BigBlockRanger, Mark Miller and John Myrick like this post
Gregaust and Mark Miller like this post
We can't wait to drop that 460 in there!
69F100 and Mark Miller like this post
$70 later, a new pan is ordered.
Once that was all done, he grabbed the welder and welded the engine mount perches to the frame. He did as good or better job than I could have.
All four tires and two wheels were also delivered today. He went with a 205/75-15 front and a 275/60-15 rear. The front wheels are 15x6 Torque Thrusts and the rears will be 15x8's. Of course we had to test fit a wheel.
It is really starting to come together!
With that major hurdle cleared, Judd has a lot more things he can work on now!
Sometimes, you have to go backwards to go forward. The information we had was that these Hooker headers could be installed with the engine in place. That might be true if you own a lift, but it is definitely not true for those of us working on the floor. The passenger side header slipped right in, but we could not rotate the driver's header down far enough to wiggle it up and in. After several "let's try this" attempts, we pulled the motor mount bolts, lifted the engine up and forward and laid the header in. Then we put it all back in. They fit nice once they are in, but that back bolt on number 4 has to be tightened from under the car.
Mark Miller- Posts : 1957
For such a big car, the engine sure seems to sit high. Hood clearance is going to be an issue I think....
I think you are way past the budget of someone in high school.
BigBlockRanger wrote:Good catch. We'll check into that.
Just add a Boss9 scoop!
wickettoby1- Posts : 352
BigBlockRanger likes this post
rmcomprandy wrote:Personally,,,
Kinda depends on the high schooler I suppose. Judd is a go-getter and worked 2 jobs this summer and 1 job during the school year. Granted, I had some core parts available that he has made use of, but he has funded 99% of the stuff for this project. Only things I bought for this car were stuff I broke or stuff I told him I had on hand, but either lost or misplaced, like the harmonic balancer and brake booster.
He's a good kid, and has received appointments to the Air Force Academy and the U.S. Naval Academy (hasn't picked which one yet and it's killing me!). He has to report to either at the end of June so we'd like to have it running and driving well before then.
My 78 LTDII i used motor mounts from a 72 Thunderbird IIRC that had a 429 or 460 in it.I had a Weiand 8012 on my 466 in the LTDII and had no hood clearance problems with a drop base air cleaner but don't remember how tall the air filter was!!
Not our car, but this is exactly what we are dealing with.
Oh, and Judd chose the Air Force Academy over USNA. His brother will be a senior there next year, so they will have one year together.
The power steering pump is now cleaned, painted and installed. We also bent up a steel fuel line from the pump up near the carb feed line.
Crossmember is basically done. Good enough to stick under a car and never be seen again. We'll shoot some paint on it.
» 352 FE 1962 Ford Donated High School Auto Shop Engine
» low budget 460 build up
» need help budget build 460
» Budget build questions
