how fast are you 545-557 Ci guys with dove heads
studly
johndickjr
how fast are you guys with 545-557 motor running using ported Dove heads, in a door car, and which would be better, a built 466 with a big roller and 13-1 compression with ported doves or a 545 with a roller and 13-1 compression,
johndickjr- Posts : 896
Re: how fast are you 545-557 Ci guys with dove heads
IMO the stroker will always make more power even if limited by heads
studly- Posts : 512
Depending on how well set up the DOVE's are, 700+ hp is not out of the question. You can plug that hp number into a Wallace calculator with your weight and be able to get a real close projected ET. More cubes = more TQ and the car with the most TQ will go faster every time, with all else being equal.
schmitty- Posts : 4538
went 10.40's at 3375#'s, 472 deal, like 20 years ago.............around the time of ebay and all............
Sometime before September, 1995, 28-year-old software developer Pierre Omidyar, who had previously worked with Claris developing software for Apple computers, sat down to write the code that would eventually evolve into what we know as eBay today.
Greg_P- Posts : 1009
514, home ported D2ve's milled to hell, 13:1, 3200 lb., 6.30 112 mph 1/8 mile. Glide 4:10,s 28x10.5's
In 1998 the 472 w/ported Dove-C (offset grd. 429 steel crank,6.7 rods,.030 Venolia's)C6, #2970 w/me., in a Maverick went 9.85 in 1/4 and 6.26 in 1/8.
» how fast did you go with DOVE,C9VE,OR C9VE HEADS?
» A429 Heads VS Dove-c Heads
» DOVE-C V/S EDELBROCK PERFORMER 60679
» switching D0OE-R head to DOVE-C heads
