help with block ID?
help with block ID? Empty help with block ID?
Post  irish January 28th 2010, 12:51 pm
Local fellow has a block with the C9VE-B stamp, claims it is a 429 from a 1970 Torino GT.
Wants 150 for it and it is standard bore. Good block worth building?
thanks
Matt
irish
help with block ID? Empty Re: help with block ID?
Post  tall69 January 28th 2010, 1:51 pm
It's an early block with a shorter deck height. It would be a fine choice for a build depending on the goals. What are you looking to build out of it?
If you want to buy a stroker kit, a D1 block would give you a little more deck material to square down to 10.300". Also, $150 sounds a little strong. Depending on where you are located, they should be available for $100.
tall69
tall69
Post  irish January 28th 2010, 1:58 pm
Mid sized stroker for a nasty street car motor. Maybe run it as the track 2-3 times in its life.
Good for that or look for another?
irish
Post  dfree383 January 28th 2010, 2:31 pm
Its fine Block for a build and the price is fine as long as its clean and has now issues that need repaired.
Post  lghting94 January 28th 2010, 5:54 pm
I agree with dfree that sounds like a good price last one i sold was for $200
lghting94
lghting94
Post  bbf-falcon January 28th 2010, 9:13 pm
dfree383 wrote:Its fine Block for a build and the price is fine as long as its clean and has now issues that need repaired.
X3.
