Popping from passenger side exhaust when first started
Popping from passenger side exhaust when first started Empty Popping from passenger side exhaust when first started
Post  nuclearcobra February 9th 2010, 8:34 am
this is on my 302 with the kaase canted valve heads the last two times i started it it was popping like a fire cracker it seems like from just one cylinder then about 20 seconds it clears up and is fine. I'm wondering if its a sparkplug i have the autolite ar3934 gapped to 45. The reason i'm leaning towards the plug is it clears right up and is fine after that. i know on my yellow mustang with the 472 once in a while when it first starts after sitting for a while it seems lazy at first then clears up and sounds better and revs better so maybe its the same on the 302 o and it was in the low 30's out when started. Any other ideas ? maybe plug gap too big?
nuclearcobra
nuclearcobra
Popping from passenger side exhaust when first started Empty Re: Popping from passenger side exhaust when first started
Post  cletus66 February 9th 2010, 10:43 pm
Maybe you fouled one out. It may clear up and idle fine, but when you put a load on it, it might start missing again at higher rpms. I have had this happen with resistor plugs.
Post  paulie February 10th 2010, 1:19 am
I had a similar problem once it popped through the exaust until it started to warm up and it was a bad header gasket. once it started to warm up it sealed itself.
paulie
Post  dfree383 February 10th 2010, 8:20 am
Bad Plug? Valve Sticking?
Post  nuclearcobra February 10th 2010, 8:48 am
Thanks for the replys i'll check the plugs as far as the gap .045 should be fine you think ? using all msd ignition.
nuclearcobra
nuclearcobra
