Fel Pro Intake Gaskets
+16
nuclearcobra
blown473
MBBFord
Gregaust
bb429power
Greg_P
342g
Bret Powell
strokedmyford
Baitshop
20 posters
Fel Pro Intake Gaskets Empty Fel Pro Intake Gaskets
Post  Baitshop February 28th 2010, 8:06 pm
I know this has been hashed over on the other board, but I figured I'd post a pic. I tear the engine partially apart every year, and this will be the last set of fel pro intakes I'll use. Last years set looked about the same. Time to try a different brand I guess.
Fel Pro Intake Gaskets DSC00010-3
-Jared
Baitshop
Fel Pro Intake Gaskets Empty Re: Fel Pro Intake Gaskets
Post  the Coug February 28th 2010, 8:49 pm
Jered I think you have something wrong check your head surface with a strait edge and then double check your intake flange, that gasket looks like it is crushed excessively, making me think you have a straitness issue, and another thing is those are 3/8 bolts they only have like #25 to 30 psi torque.... and thats not very much..... Most people over torque the intakes and valve covers by a bunch....
Post  Baitshop February 28th 2010, 9:00 pm
Hey Coug, I had thought of that. I always tighten them in sequence, in steps, and to proper torque. I'm kind of(read really) obsessive compulsive, so I always end up quintuple checking them. The center four bolts always seem to need a little extra twist each time before reaching the full torque value. Perhaps I should just torque them once, walk away, and then seek some therapy for my ocd.
-Jared
Baitshop
Post  bruno February 28th 2010, 9:03 pm
i believe Cometics has a gasket that replaces the felpro 1231 ..... its the C5206-060 ......
http://WWW.CKRME.COM
Post  the Coug February 28th 2010, 9:12 pm
Jered I have used FelPro's and FMS and never had a problem one,,, I have even reused them several times and sealed perfectly...... Fel Pro Intake Gaskets Icon_eek but I also NEVER use end gaskets they Automaticly go to the Trash and use Silicon on the end.....
I would still double check in just in case...
Post  bbf-falcon February 28th 2010, 9:46 pm
the Coug wrote:Jered I think you have something wrong check your head surface with a strait edge and then double check your intake flange, that gasket looks like it is crushed excessively, making me think you have a straitness issue, and another thing is those are 3/8 bolts they only have like #25 to 30 psi torque.... and thats not very much..... Most people over torque the intakes and valve covers by a bunch....
X2
Post  Baitshop February 28th 2010, 9:55 pm
The other head looks exactly the same. I machined .020 off both sides of the intake during initial assembly, so that's straight. Could both heads be warped on the intake side? These heads are not a matched pair either, meaning they came from two different donor engines.
-Jared
Baitshop
Post  strokedmyford February 28th 2010, 10:48 pm
Use felpro 1231S-3 it has a steel core and very reliable. I checked the part number today and it is correct.
strokedmyford
strokedmyford
Post  Bret Powell February 28th 2010, 11:15 pm
These type FelPro intake gaskets are crap. I've had numerous of these do this very thing on both BBC and BBF. I've even had to waranty these gaskets on three BBC marine engines. I do not use them anymore for anything that will be assembled for more than a season.
Bret
Bret Powell
Post  342g March 1st 2010, 12:34 am
Bret Powell wrote:These type FelPro intake gaskets are crap. I've had numerous of these do this very thing on both BBC and BBF. I've even had to waranty these gaskets on three BBC marine engines. I do not use them anymore for anything that will be assembled for more than a season.
Bret
Well we are waiting, Very Happy what do you use? Laughing Laughing
342g
342g
Post  Mark Miller March 1st 2010, 12:41 am
I agree with Bret after taking my intakes off that were on 2 to 3 years my Fel Pro gaskets looked like the pictures above.I used the Mr Gasket Ultra Seals last summer,i'll see what they look like next time i have the intake off.
Later Mark.
Post  rmcomprandy March 1st 2010, 9:57 am
Call Fel-Pro and they will tell you that their race gaskets are meant to be temporary unless you get their offerings with metal sandwiched in them.
I use the Mr. Gasket intake gaskets; the regular ones not the Ultra Seal versions.
Post  Bret Powell March 1st 2010, 4:32 pm
rmcomprandy wrote:Call Fel-Pro and they will tell you that their race gaskets are meant to be temporary unless you get their offerings with metal sandwiched in them.
I guess that's as good an excuse as any, and I've heard. So my next question is... Why are they offered in all Felpro marine gasket sets I get a hold of? Performance or not. Don't bother trying to contact FelPro about it because their company makes no sub-standard gaskets.
On another note I think their head gaskets are very good.
I have not settled on any one gasket but, I do like the Mr Gasket Ultras, and am always looking for better. I've heard good things about Victor's intake gaskets, but I have not got a good source for them.
Bret
Bret Powell
Post  strokedmyford March 1st 2010, 4:46 pm
I've used the felpro 1231s-3 in 3 different mud race engines and when it was time to freshin I swear you could have reused the intake gaskets. Plain 1231's are junk IMO.
strokedmyford
strokedmyford
Post  Greg_P March 1st 2010, 5:45 pm
I know the 1230/1231's have a bad rap. But I have had very good luck with them. I use adhesive (not RTV) on the gasket to hold it onto the head. Then the secret is to not overtighten the intake bolts.
I have had them look like brand new after two years of street/strip use.
Greg
Greg_P
Greg_P
Post  bbf-falcon March 1st 2010, 6:30 pm
Yea me too. I can't really say anything bad about the Felpro printoseal. I don't use anything w/them except for silicone on the ends. Maybe i was just lucky Smile
Post  bb429power March 1st 2010, 6:33 pm
Guess you've never heard the expression "Fel-pro means hell no"!
bb429power
bb429power
Post  bb429power March 1st 2010, 6:38 pm
X2
Yeah, X2. did you cut your deck? If you did then you also need to shave a certain amount off of the intake too. That might be it.
bb429power
bb429power
Post  Baitshop March 1st 2010, 9:53 pm
Baitshop wrote:The other head looks exactly the same. I machined .020 off both sides of the intake during initial assembly, so that's straight. Could both heads be warped on the intake side? These heads are not a matched pair either, meaning they came from two different donor engines.
-Jared
Baitshop
Post  Gregaust March 2nd 2010, 4:22 am
I had a set go the same way. I went to the MrGaskets and been good . Got some Victor Reinz gaskets as recommended ,they are nice but i've not used them yet
Gregaust
Post  bruno March 2nd 2010, 10:19 am
Mr. Powell
do you have a any part #'s for the gaskets you use ?
Post  rmcomprandy March 2nd 2010, 10:35 am
bruno wrote:Mr. Powell
Not Bret but, the Mr. Gasket Cobra Jet "Ultra Seal" gaskets are #5839 and the Mr. Gasket Cobra Jet regular gaskets are #208A.
Post  bruno March 2nd 2010, 10:42 am
thxs Randy Wink
Post  MBBFord March 2nd 2010, 2:53 pm
Are those felpro gaskets the ones that come in the Ford Racing gasket set?
I don't have them with me to check the number.
Best bet is to not over tighten the intake, or get a different gasket?
MBBFord
Post  Bret Powell March 2nd 2010, 8:55 pm
How does one "overtorque" the intake and smash the gaskets when they are being torqued to spec?
Bret
Bret Powell
