finally got the carb. fixed
Went to Atco and made my first pass and ran a10.62 stumbling off the line, and laying over at half track. Came in and took the carb. off and put nuclearcobra's 950 hp on went out and ran a 10.37 at almost 130mph. Called Chuck Nuytten and he told me what to look for. While checking the carb. out I noticed the secondary squirters weren't working. The screw had backed out of the shaft and the cam wasn't working. I also noticed the base screws were loose. Tightened the screws and put on lock tight, put the carb. back on and ran a 10.32 @130.95. in 80 degree weather. Man I am pumped! My car is back!
514Fox87- Posts : 436
Re: finally got the carb. fixed
great to hear that the car is back.
'65 T-BOLT- Posts : 1464
» Installed an early 90s starter on my drag car it runs on with the engine
» Pushing water out of radiator?
» It's fixed!!!
» C-6 wont shift untill high RPM
» CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE
» It's fixed!!!
