oil pressure droping on take off
D. Sea
mustangjeff
I have a 477 na bracket motor with stock 6 quart front sump pan & when coming off of trans brake the oil pressure drops down for a brief moment. I know I need to switch to a good rear sump pan, just wondering if for now I could try adding another quart of oil to see if its any better?
mustangjeff- Posts : 87
Re: oil pressure droping on take off
one would'nt hurt.does your pan have anything at all in it or is it open?
Try taking off slower.
Curt- Posts : 2791
if you had a cj or p/i pan it'd help a lot.the rear sump or flat bottom pans can be a PIA too,in shutdown.i run a flat pan and i loose psi at the end of the track for a second.i've got it down now and all looks fine so it's not a big deal but i wish it did'nt do that.
Thanks for the help cool40.
A better oil pan is badly needed and an oil pressure accumulator would really help.
D. Sea- Posts : 2768
deeper pan and a windage tray will help alot.....
the Coug- Posts : 3055
I ran a Milidon 9qt. kickout pan w/windage and baffles in the ole Maverick. never had any problems.
Why not weld in a simple 1-1/2" to 2" long baffle side-to-side at the back of the sump to keep more of the oil from climbing out of the front sump during the launch?
DILLIGASDAVE- Posts : 2262
GET A PAN !
LivermoreDave- Posts : 972
Front sump ISN'T the problem ... the oil pan internal design IS ... as Dave said - "get a pan!"
