tuning help
tuning help
ok, so i have the MSD Pro Billet distributor for the 460.....
any tips for setting it up for street use.....do I need to hook up a vacuum line from the advance to the carb....
it came with other spring and some basic instructions, but i figure like all they are a generic instruction, so I figure the guy who have installed one on their motor will have ssome real time experience
466
10.5:1
zero deck
pi head
open header
edel brock 750 carb for street use , 1050 domi for track (feel free to offer suggestions for dizzy setup for either)
stealth intake
electric fuel and water
frank
466
10.5:1
zero deck
pi head
open header
stealth intake
frank
Re: tuning help
also, has been recommended by a buddy who does small block stuff, to add a PCV to the car (dont have one now)
says will run better with it.....
Re: tuning help
Pvc is fine for a street motor, as far as distributor set up, figure how fast you want the timing to come in and follow the instructions to install the suggested advance springs....... Then set the timing to around 32 total to start, not initial, should be in the 10-14 initial range.....
Re: tuning help
dave,
can you clarify a few things for me
1. intitial timing is at idle......correct? should be 10-14
2. advanced timing is at what rpm.....the instructions dont give a number, is that at full throttle or part throttle?
3. total timing is the sum of initial and advanced? should start about 32 and work up/down from there depending on what?
keep in mind i am newbie at this carb/distributor stuff...i tried to read the manual a few times, but some of it is jibberish right now......
frank
frank
Re: tuning help
1. Yep
2. You need to look at the charts provided different bushings and springs have different totals in at different rpm
3. Yes, but the total won't change for a given set-up unless you advance or retard the actual distributor. Generaly you should be all in somewhere around 2000-3000 rpm but that depends on what your set up wants
Re: tuning help
so not to keep bugging you....
the centrifugal advance which you set with the springs and stuff....does that work in conjuction with the vacuum advance, or do i lock one of them out....
Re: tuning help
All of this is done without the vaccum advance
Re: tuning help
Put in the black 18-degree centrifugal bushing, and 2 blue (light) springs. Set your initial to 14-degrees. That will give you 32 degrees total.
After doing the above, get a vacuum gauge and tell us what your idle and cruising down the freeway at 70 mph in high gear readings are. Hook the gauge to the manifold. Do all the above with the vacuum canister on the distributor disconnected.
Hope that helps,
Dave
Hope that helps,
Dave
DJOHAGIN- Posts : 91
» What do I need to do to get this thing to run 10.0's? Sorry long post.
» Tuning and ET ?
» Tuning help
» Tuning off EGT's
» Tuning Help
» Tuning and ET ?
» Tuning help
» Tuning off EGT's
» Tuning Help
