Take a guess at the HP on my 598 - #'s posted
+12
138
jcoxracing
56Tbird
BB94STANG
valleydawg
16 posters
Take a guess at the HP on my 598 - #'s posted Empty Take a guess at the HP on my 598 - #'s posted
Post  valleydawg June 27th 2010, 9:45 am
Ok guys I did the dyno thing yesterday and I learned a lot in a short time about the motor. It was extremely hot yesterday with the inlet air around 99-100. Anyway here are a few of the details. SVO block, Bryant crank, Diamond pistons, BME rods, Kaase pump, ATI damper, A460 heads (ported by Kaase clan), T&E, Manton, Crower, Comp, A460 intake (matched), SV-1 carb, 2 Speedtech fogger systems, …built for lots of juice. Start the guessing game and I will fill you in tomorrow.[img]Take a guess at the HP on my 598 - #'s posted IMG_1116[/img]
valleydawg
valleydawg
Take a guess at the HP on my 598 - #'s posted Empty Re: Take a guess at the HP on my 598 - #'s posted
Post  BB94STANG June 27th 2010, 9:50 am
997
BB94STANG
BB94STANG
Post  56Tbird June 27th 2010, 9:59 am
1058 n/a and 1566 on the hose cheers king
56Tbird
56Tbird
Post  jcoxracing June 27th 2010, 10:18 am
1010 straight motor and 1490 on the gas
Justin
jcoxracing
jcoxracing
Post  bruno June 27th 2010, 10:30 am
im going to say with the proper quench, cam, comp...it should make 1023 on muscle and with both foggers on ...(just remember he is using soft lines for one of the guns )..... it should make around 1503 cheers
http://WWW.CKRME.COM
Post  dfree383 June 27th 2010, 10:42 am
What's the head flow, compression and cam specs? Guess to follow...... Cool
Post  bbf-falcon June 27th 2010, 11:42 am
1100 NA and 1475 on spray
Post  69F100 June 27th 2010, 3:01 pm
985 n/a on the baby bottle 1326
Post  Nevs June 27th 2010, 3:54 pm
dfree383 wrote:What's the head flow, compression and cam specs? Guess to follow...... Cool
X2..... Idea
Post  138 June 27th 2010, 3:59 pm
937.. na
138
Post  whatbumper June 27th 2010, 4:10 pm
I am going to assume some things here: 1) conservative tune 940hp 2) no nitrous on dyno
Post  valleydawg June 27th 2010, 5:01 pm
14/1, comp roller w 850 lift, pretty conservative tune up and only spray twice with one system (100/150). Didnt want to break it on the dyno...that needs to be saved for the track!
valleydawg
valleydawg
Post  Nevs June 27th 2010, 5:19 pm
valleydawg wrote:14/1, comp roller w 850 lift, pretty conservative tune up and only spray twice with one system (100/150). Didnt want to break it on the dyno...that needs to be saved for the track!
Any flow numbers?
Post  whatbumper June 27th 2010, 5:59 pm
bruno wrote:im going to say with the proper quench, cam, comp...it should make 1023 on muscle and with both foggers on ...(just remember he is using soft lines for one of the guns )..... it should make around 1503 cheers
One of my friends uses one kit with hard lines and the other soft lines and for packaging reasons I think they are pretty cool and they have a plate under each carb. Very Happy They have been running .036 jets in the soft line kit. Is that about the limit for reliability on a soft line kit?
Post  c.evans June 27th 2010, 6:18 pm
I see the crank trigger and the vacuum pump,,,,,,,what I don't see are the valves. Are they titanium or stainless steel? Hp guess to follow. Also, what was the correction factor on the dyno yesterday? Looks like a SuperFlow dyno,,,,who's??
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  valleydawg June 27th 2010, 7:44 pm
Charlie - Stainless valves...wish they were titanium. Only turned it to 7200 yesterday. You are right it is a Superflow....I am not giving the correction factor numbers...only the bottom line numbers.
News - no flow numbers. Ported by Kaase...long story.
valleydawg
valleydawg
Post  138 June 27th 2010, 7:50 pm
I've got ALL night... are the numbers so impressive that they must be held to ninja status? or is it the other way around bounce
138
Post  Lem Evans June 27th 2010, 8:23 pm
With the 1 x 4 manifold the deal should have peaked by 7,200ish rpm. I've never ran a wet sump deal on the dyno with a vac. pump . What was the vacuum in the crankcase at WOT and what was the ring package and I'll offer a w.a.g.
Post  valleydawg June 27th 2010, 8:47 pm
Vacuum was at 4.0 at WOT…I didn’t know it was so important until the dyno section. Man you can really see what it is doing with the engine. Dang I learned so much in one day. It is well worth the money. Lem I will need to check my book but it seems like I set the top ring at 32 and the next at 28. Loose for the juice. Give it a shot. Remember it was hot... 100.
valleydawg
valleydawg
Post  Lem Evans June 27th 2010, 8:55 pm
Ring package being.........043" or 3/16 .....gas port or no....etc.
Ring gap aint as big a deal as we thought 10 years ago.
Post  dfree383 June 27th 2010, 9:49 pm
1057 N/A Corrected
Post  cool40 June 27th 2010, 11:03 pm
1110 N/A Question Laughing
Post  ThndrChkn June 27th 2010, 11:09 pm
bbf-falcon wrote:1100 NA and 1475 on spray
Dangit Rick! Laughing
X2.
Doug... Cool
ThndrChkn
ThndrChkn
Post  Nevs June 27th 2010, 11:15 pm
1070 N/A, no idea with the spray.....
Take a guess at the HP on my 598 - #'s posted Empty The scoop
Post  valleydawg June 28th 2010, 6:54 am
I made 2 short pulls to break in the rings, make sure everything was ok etc. and then seven full pulls. Best pull was 1000 hp on motor at 7200. That was with the air at 99-100 and remember this is a nitrous motor not a pure hp motor. I was not even thinking about it being hot! With good air the thing should go 1050 maybe. I wanted to spray the motor just to see if Speedtech’s 100 hp set up is really 100 hp and so on. With 150 shot the motor made 1141. I am pretty happy with the results. I was hoping for 1000 and got a couple hp to spare.
I could not believe all the tension/nervousness that I was feeling that morning. I sure didn’t expect any of that. The whole plan has been for the motor to be strong enough for around 450 -500 on the juice…man do I have a surprise for the little red car…hope she is up to it!
I will post my day at the dyno later. I had a good screw up that you will like.
valleydawg
valleydawg
