IDT porn now with flow #'s!
+17
Barney
DanH
LETHAL_DOSE
Frank Kramer
studly
21 posters
Page 1 of 4 1, 2, 3, 4  Next
IDT porn now with flow #'s! Empty IDT porn now with flow #'s!
Post  cool40 July 6th 2010, 10:05 pm
these sure are some big holes to fill uncle charlie! i think you can do it. Laughing IDT porn now with flow #'s! Idt_0110IDT porn now with flow #'s! Idt_0111IDT porn now with flow #'s! Idt_0112
IDT porn now with flow #'s! Empty Re: IDT porn now with flow #'s!
Post  Nevs July 6th 2010, 10:16 pm
Nice, available now? Price.....flow numbers......?
Post  cool40 July 6th 2010, 10:33 pm
Nevs wrote:Nice, available now? Price.....flow numbers......?
been available for a while,these were a good deal,too good to tell. Laughing the cnc flow # are 511in-350ex w/o pipe.2.5 intake valve,1.880ex. i will flow these when i get my valves from uncle charlie and we'll see what they do.they should have been 85cc's but they were 100cc's,so who know's what they'll flow. Smile
Post  Nevs July 6th 2010, 10:40 pm
I'm surprised they are only 10 bolt heads.
Post  richter69 July 6th 2010, 10:44 pm
You musta got confused...aint no porn in here, just some pictures of some cyl heads................. Sleep
Post  cool40 July 6th 2010, 11:31 pm
richter69 wrote:You musta got confused...aint no porn in here, just some pictures of some cyl heads................. Sleep
this aint yeller bullet Laughing this is where the HeRo's hang out. Laughing
Post  cool40 July 6th 2010, 11:37 pm
Nevs wrote:I'm surprised they are only 10 bolt heads.
pistons have sure been tuff to get.the valve size and chamber shape are not the usual,BUT Lem is on the case so i'm sure it'll happen soon.he's already sent me most of the parts to put it together,and he will call you back too Shocked hell of a good guy.
Post  dfree383 July 7th 2010, 7:03 am
Look at the size of the hole on that !!!! Laughing Laughing
Post  dfree383 July 7th 2010, 7:04 am
Need to make a mould and send it off to get scanned.
Post  c.evans July 7th 2010, 11:01 am
Just north of the 'Bama state line,,,, Laughing
Nice heads! Your blueprint sheets are done, and custom titanium Victory 1 valves have been ordered. Cool
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  cool40 July 7th 2010, 1:20 pm
c.evans wrote:Just north of the 'Bama state line,,,, Laughing
Uncle Charlie
thanks Charlie! Very Happy
Post  Nevs July 8th 2010, 6:12 pm
Never mind, checked out the website and found most of the answers to my questions. Which intake valve are you going to run, the 2.450" or the 2.500"?
Which valve cover do the take, I thought I counted eight mount points in the picture. Also, do the standard TFS intakes work? I tried to call the today, no answer....
Post  IDT-572 July 8th 2010, 7:51 pm
2.500 intake valve 1.88 exhaust All A460 stuff will fit,
Post  Nevs July 8th 2010, 8:50 pm
IDT-572 wrote:2.500 intake valve 1.88 exhaust All A460 stuff will fit,
10-4 Blake. I might have to try a set when I get my other issues straightened out..... Idea
Post  IDT-572 July 8th 2010, 9:32 pm
I have a set with the 2.450 intake and 1.880 exhaust.
Curious as to how Lee's will run.
Post  cool40 July 8th 2010, 9:39 pm
we gona see what they do on a 572.4.625x4.250 with all the compression Lem can get diamond to put in the hole!Blake's got the cam spec's in his head somewhere,much as i'v bugged him he may keep it. Laughing
Post  studly July 8th 2010, 9:51 pm
so does stock a460 valvetrain work or do you have to custom rockers? Different length push rods?
studly
studly
Post  Nevs July 8th 2010, 10:12 pm
studly wrote:so does stock a460 valvetrain work or do you have to custom rockers? Different length push rods?
From what I read on their website, all the A460 stuff is interchangeable. I'm impressed by the flow numbers if they are accurate....
Post  cool40 July 8th 2010, 11:01 pm
the push rods i dont know about yet,the rest is same as a460.the deal with the valves bee'n so big,as Lem said "big as a cows ass",they get heavy and heavy dont like high rpm.these heads are high rpm or big inch so ti valves are a must or it's a waste.at about the same point the shaft rockers start to look like a good idea too but i'm gona run the crower's for now and see what happens. Smile
Post  dfree383 July 9th 2010, 10:16 am
That set of yours is pretty damn nice too.
Post  cool40 July 9th 2010, 7:31 pm
dfree383 wrote:That set of yours is pretty damn nice too.
thanks! Cool
Post  G-Code July 12th 2010, 1:44 am
I wonder what's the most you could mill them down if you wanted to and what an angle mill would do?
I'd be interested in the flow numbers, I have two friends working on 582's (one for sure the other might do a 565) I told them about the IDT heads. I wonder if they flow what they advertise? Hope so, but I know a guy who flowed a set some years back.........
Hope yours flow as advertised.
G-
Jon
Post  Frank Kramer July 12th 2010, 5:12 pm
cool40 wrote:the push rods i dont know about yet,the rest is same as a460.the deal with the valves bee'n so big,as Lem said "big as a cows ass",they get heavy and heavy dont like high rpm.these heads are high rpm or big inch so ti valves are a must or it's a waste.at about the same point the shaft rockers start to look like a good idea too but i'm gona run the crower's for now and see what happens. Smile
I would realy put a set of shaft rockers on them. There is not much difference between studs/ rockers and girdle or a good set of shaft mounted. But the shaft mounted are much better.
How much lift and seat pressure are you going to run?
Frank Kramer
Frank Kramer
http://www.seasideaffair.com
Post  cool40 July 12th 2010, 9:38 pm
i dont know what the open psi will be but seat should be 280-300 @ 2.100.the springs are manley green's from Lem.
Post  Lem Evans July 12th 2010, 9:49 pm
If/when a guy had an A460 cyl head designed for a shaft rocker deal it'd be cool ......I aint seen one yet.
