IDT porn now with flow #'s!
+17
Barney
DanH
LETHAL_DOSE
Frank Kramer
studly
21 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: IDT porn now with flow #'s!
Lem Evans wrote:If/when a guy had an A460 cyl head designed for a shaft rocker deal it'd be cool ......I aint seen one yet.
Where's that pic of Philip's deal with the valve cover off?
well what the hell was you try'n to sell me the other day?Lem Evans wrote:If/when a guy had an A460 cyl head designed for a shaft rocker deal it'd be cool ......I aint seen one yet.
Does someone make a set that take less set-up than T&D's ?
After running mine I'll run shafts anytime I have the money to do so. When I get around to building my spare engine I'll use my old Crower S/S enduros and Jomar set-up.
G-
G-Code- Posts : 193
Jesel sells a set as well, but you need to grind on them to make them fit. WW eng. sells some, but I have never used them to tell you what they are like. Charlie can give you some insight on the WW engineering ones.
On my IDT heads they have been milled to 73cc. Mine are solid, no water ports and seem to flow really well, better than I thought. I remember they peaked a little over 500cfm with a 2.4250 intake valve.
LETHAL_DOSE- Posts : 62
got some #'s on them today...... in..200=176.300=241.400=321.500=400.600=452.700=472.800=486.900=498 ex..200=153.300=204.400=246.500=302.600=334.700=348.800=359.900=368
cool40 wrote:got some #'s on them today...... in..200=176.300=241.400=321.500=400.600=452.700=472.800=486.900=498 ex..200=153.300=204.400=246.500=302.600=334.700=348.800=359.900=368
Very nice numbers indeed!
Nevs- BBF CONTRIBUTOR
Frank Kramer wrote:cool40 wrote:the push rods i dont know about yet,the rest is same as a460.the deal with the valves bee'n so big,as Lem said "big as a cows ass",they get heavy and heavy dont like high rpm.these heads are high rpm or big inch so ti valves are a must or it's a waste.at about the same point the shaft rockers start to look like a good idea too but i'm gona run the crower's for now and see what happens.
I would realy put a set of shaft rockers on them. There is not much difference between studs/ rockers and girdle or a good set of shaft mounted. But the shaft mounted are much better.
How much lift and seat pressure are you going to run?
What exactly is it that makes the shaft mounts MUCH BETTER ...?
The ones available for an A460 don't flex any less and aren't more stable than good stud mounts with a well made girdle.
They do however look cool, retain their lash when you remove them and replace them and cost a lot more.
BETTER is a very subjective term.
To me, better means more power, less deflection and higher durability and they won't do ANY of those things, especially with high valve spring pressures and big pushrods.
Spend the money to DO the Spintron testing and find out the truth of the matter.
EDIT: Ben Franklin once said, "Just because 50,000 people believe in a dumb idea ... it's still a dumb idea".
Last edited by rmcomprandy on September 13th 2010, 10:05 am; edited 2 times in total
thats what i like about these heads,A parts and C numbers.rmcomprandy wrote:Frank Kramer wrote:cool40 wrote:the push rods i dont know about yet,the rest is same as a460.the deal with the valves bee'n so big,as Lem said "big as a cows ass",they get heavy and heavy dont like high rpm.these heads are high rpm or big inch so ti valves are a must or it's a waste.at about the same point the shaft rockers start to look like a good idea too but i'm gona run the crower's for now and see what happens.
What exactly is it that makes the shaft mounts BETTER ...?
cool40 wrote:rmcomprandy wrote:Frank Kramer wrote:cool40 wrote:the push rods i dont know about yet,the rest is same as a460.the deal with the valves bee'n so big,as Lem said "big as a cows ass",they get heavy and heavy dont like high rpm.these heads are high rpm or big inch so ti valves are a must or it's a waste.at about the same point the shaft rockers start to look like a good idea too but i'm gona run the crower's for now and see what happens.
The ones available for an A460 don't flex any less and aren't more stable than good stud mounts with a well made girdle. thats what i like about these heads,use all the stuff you have already got for your A heads and make the power of a C head!
Adding something I've said in the past about these heads to my last post isn't really beneficial as it doesn't exactly have anything to do with the valve train.
that was a f#$% up,didnt mean to make it look like YOU said that Randy.i didnt scroll down when i quoted you and it looked that way,tried to edit it but couldnt,sorry.rmcomprandy wrote:cool40 wrote:rmcomprandy wrote:Frank Kramer wrote:cool40 wrote:the push rods i dont know about yet,the rest is same as a460.the deal with the valves bee'n so big,as Lem said "big as a cows ass",they get heavy and heavy dont like high rpm.these heads are high rpm or big inch so ti valves are a must or it's a waste.at about the same point the shaft rockers start to look like a good idea too but i'm gona run the crower's for now and see what happens.
there is a few benefits to shaft rockers . imo the #1 is not stuck with the OTS ratios . want a 1.90 ratio , you got it
DanH- Posts : 1081
I USE THE JESSEL ON THE EX 514 HEADS, WELL WORTH IT, FOR THE RPM THESE HEADS NEED TO SEE I WOULDNT RUN A STUD MOUNTED ROCKER
BOSS 429- Posts : 2372
G-Code wrote:Lem Evans wrote:If/when a guy had an A460 cyl head designed for a shaft rocker deal it'd be cool ......I aint seen one yet.
G-
THERES issues with the t &ds, you have to either weld the stands ,or pin them for the a head, jessel bolt together,no matter which you use theres work to do for stand height
-rich
i wouldnt mind having shaft rockers but i have crower's now on my A460's.race parts are a big enough PIA when they "bolt on",with all the talk about stands and welding and b/s,i'm stayen with the studs for now.
Nice numbers cool40. Were the exhausts flowed with a test pipe?
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
no,that was without.the ex. was better than i thought it would be but intake was a little less.i went back and looked at eliminator's web site and it's not realy clear where the "peak" #'s they speak of are at.we only went to .900 and these things can be bought with springs to go over 1.0 so who knows. the .500 #'s were pritty good i i thought.the guys who flowed them said that a stainless valve would show a better number than a ti. would,becouse of the thin edge on the head? you ever saw that Charlie?c.evans wrote:Nice numbers cool40. Were the exhausts flowed with a test pipe?
Uncle Charlie
BOSS 429 wrote:Lem Evans wrote:If/when a guy had an A460 cyl head designed for a shaft rocker deal it'd be cool ......I aint seen one yet.
"WELL WORTH IT" is totally subjective.
I just know your OPPINION is much more conducive than any actual testing on a Spintron could possibly be. After all, YOU SAID SO, lol.
rmcomprandy wrote:BOSS 429 wrote:Lem Evans wrote:If/when a guy had an A460 cyl head designed for a shaft rocker deal it'd be cool ......I aint seen one yet.
LOL, NO NOT SAID IT,TESTED IT, ROCKER IS MORE STABLE AT HIGHER LIFTS AND RPM THAT THESE,AND THE EX514 HEAD NEEDS FOR MOST POWER, THIS ALSO EXTENDED VALVETRAIN,
LIFE. WE HAVE RAN THESE TO 10,100 RPM FROM 27 RUNS,TO 40 SEC RUNS AT A TIME. THIS IS FACT. YOU SAID SOMETHING?
cool40 wrote:no,that was without.the ex. was better than i thought it would be but intake was a little less.i went back and looked at eliminator's web site and it's not realy clear where the "peak" #'s they speak of are at.we only went to .900 and these things can be bought with springs to go over 1.0 so who knows. the .500 #'s were pritty good i i thought.the guys who flowed them said that a stainless valve would show a better number than a ti. would,becouse of the thin edge on the head? you ever saw that Charlie?c.evans wrote:Nice numbers cool40. Were the exhausts flowed with a test pipe?
Uncle Charlie
cool40,
I have not seen a thin margin, or edge as you call it, help or change the flow very much on the intakes. However, "they" may have had a thin margin stainless steel valve there for you to verify or test what they are saying.
Of course as you know, we generally like for the margin thickness to be greater on a titanium valve, just for a strength issue, because titanium is not as strong of a metal, as the stainless steel alloys. Too thin of a margin, and too much spring pressure, results in a titanium valve being swallowed. Also, steeper seat angles make it worse from a physics standpoint.
On the exhaust side,,,,exhaust valves will flow better with a thicker margin than a thin margin.
Hope this helps,
Charlie
BOSS 429 wrote:rmcomprandy wrote:BOSS 429 wrote:Lem Evans wrote:If/when a guy had an A460 cyl head designed for a shaft rocker deal it'd be cool ......I aint seen one yet.
I have no doubt that you've tested those bolt down, shaft mounted rockers but, that is not near the same thing as COMPARING the performance of the two different valve train systems using the exact same tests.
if I need a 1.90 ratio -- one guess what I want . hint not 1,80 or 1.73Lem Evans wrote:Wants and needs are not the same thing.
DanH- Posts : 1081
My point is/was.....most racers do not need that lift range and will not do the maintance required to do so. Some people think that...if one could do something they should.DanH wrote:if I need a 1.90 ratio -- one guess what I want . hint not 1,80 or 1.73Lem Evans wrote:Wants and needs are not the same thing.
Most racers do not have Ti valves.....big/thick p.rods etc. ...so at that point I'd think a 1.9 rocker would not be wanted or needed .
By all means do what you need to do.
» Trick Flow A460 360cc heads cnc flow numbers
» Trick Flow vs Flow Technologies Intakes
» Trick Flow street Flow numbers
» Flow Test for.
» flow#'s
» Flow Test for.
» flow#'s
Page 2 of 4
