Best F-150 engine lineup EVER!
A look at the new engine lineup
The three new truck engines available at launch are the 3.7-liter V6 and 5.0-liter V8, each with fuel-saving and performance-enhancing twin independent variable camshaft timing (Ti-VCT) technology, and a version of the 6.2-liter V8 that is the base engine in the 2011 Ford F-Series Super Duty. Here are the highlights of each new engine:
3.7-liter four-valve Ti-VCT V6
Best-in-class 302 horsepower at 6,500 rpm vs. V6 competitors
Unsurpassed 278 lb.-ft. of torque at 4,000 rpm vs. V6 competitors
Projected best-in-class fuel economy
Best-in-class 6,100 pounds maximum trailer tow vs. V6 competitors
5.0-liter four-valve dual-overhead-camshaft Ti-VCT V8
Best-in-class 360 horsepower at 5,500 rpm vs. standard V8 competitors
Best-in-class 380 lb.-ft. of torque at 4,250 rpm vs. standard V8 competitors
Best-in-class 10,000 pounds maximum trailer tow vs. standard V8 competitors
6.2-liter two-valve single-overhead-camshaft V8
Best-in-class 411 horsepower at 5,500 rpm vs. all competitors
Best-in-class 434 lb.-ft. of torque at 4,500 rpm vs. all competitors
Best-in-class 11,300 pounds maximum trailer tow vs. all competitors
3.5-liter Ti-VCT EcoBoost
365 horsepower at 5,000 rpm on regular fuel
Best-in-class 420 lb.-ft. of torque at 2,500 rpm vs. premium V8 competitors
Up to 90 percent of peak torque available from 1,700 rpm to 5,000 rpm
Best-in-class 3,060 pounds payload vs. all competitors
Six-speed automatic transmission now standard with SelectShift available
SelectShift functionality is available in the six-speed automatic transmission. SelectShift allows customers to select the desired gear. The transmission also features progressive range select, which allows the customer to lock out the available gears while in Drive.
Also enabled is tow/haul mode, which provides better control when hauling a heavy load or towing a trailer, especially when descending grades. The improved system uses an array of sophisticated electronic sensors to better predict the driver’s need for a downshift to provide engine braking and enhanced control.
D's557BBF- Posts : 1186
schmitty- Posts : 4538
Re: Best F-150 engine lineup EVER!
They need to make this a add on feature for the 09-10 trucks.
jones- Posts : 2230
» Engine Masters 534 Boss Engine and BBF 72 Torino in the new PHR Magazine.
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» 653 CI Thor Headed big block Ford engine / ENGINE SOLD THANKS!!!!!
» Engine Masters 414" stroker 351W street/strip engine
