Tourque Steps for BBF Aluminum Head
+9
342g
95lightiningguy
JG342
studly
13 posters
Does anybody know the tourqe specs for a BBF with alumium head i know what bolts to tighten first and last just need the
20 ft pounds first
80
100
140
etc
Thanks for the help
20 ft pounds first
80
100
140
etc
Thanks for the help
studly- Posts : 512
Re: Tourque Steps for BBF Aluminum Head
On my Blue Thunder and TFS A460's I've just used 3 steps and never a problem. I also let them sit overnight after the first torque down then go back the next day and loosen then torque them one at time back to the 140.
50
90
140
with 30wt oil
50
90
140
with 30wt oil
David Cole wrote:On my Blue Thunder and TFS A460's I've just used 3 steps and never a problem. I also let them sit overnight after the first torque down then go back the next day and loosen then torque them one at time back to the 140.
50
90
140
with 30wt oil
X2,,,,,,or retorque them after they have "seen" heat.
Charlie
c.evans- BBF VENDOR SPONSOR
studly- Posts : 512
c.evans wrote:David Cole wrote:On my Blue Thunder and TFS A460's I've just used 3 steps and never a problem. I also let them sit overnight after the first torque down then go back the next day and loosen then torque them one at time back to the 140.
50
90
140
with 30wt oil
Charlie
that's what we do with our MLS stuff. get the engine warm, let it cool off, re-torque.
whatbumper- Posts : 3024
A weekly show called (Motorhead Garage) just had a interesting show all about Torquing and Fasteners.
bbf-falcon wrote:A weekly show called (Motorhead Garage) just had a interesting show all about Torquing and Fasteners.
I caught that episode myself, very good info.
JG342- Posts : 24
Can you record that for me, I dont have cable?
Curt- Posts : 2791
What channel is that on, cant seem to find it here.bbf-falcon wrote:A weekly show called (Motorhead Garage) just had a interesting show all about Torquing and Fasteners.
95lightiningguy- Posts : 570
Its on speed channel (weekends)
JG342 wrote:bbf-falcon wrote:A weekly show called (Motorhead Garage) just had a interesting show all about Torquing and Fasteners.
Our user names are close, hope you don't catch any of my hate mail.
342g- BBF CONTRIBUTOR
on our ten bolt deals w/ 3 kits we torque them to 150 plus w/ the cometic's never any problems in this camp
605FOX- BBF CONTRIBUTOR
342g wrote:JG342 wrote:bbf-falcon wrote:A weekly show called (Motorhead Garage) just had a interesting show all about Torquing and Fasteners.
LOL thanks for the heads up
JG342- Posts : 24
i know this is old thread ,
but aluminum heads with arp studs same process ??
wasnt sure if it was different using studs
5pointslow- Posts : 1408
5pointslow wrote:i know this is old thread ,
The torque value will be the same but you will get a more accurate reading because your not twisting the shank like you are with a bolt and the finer threads.
Same. I did it in three steps. Inner to outer, with the ARP lube. I used studs as well.
jbozzelle- Posts : 3705
» What's the best Aluminum head for a 460?
» aluminum head question
» History of the BBF aluminum head(s)
» Aluminum head info needed
» Aluminum Head rule
