A few spy shots
+20
Larry T
bigjohn2007
Dave C.
79ford pickup
Wheelie58
61coon
56Tbird
Barney
dr's wife racing
yellowhorse7
24 posters
Page 5 of 5 Previous  1, 2, 3, 4, 5
A few spy shots - Page 5 Empty Re: A few spy shots
Post  dr's wife racing November 12th 2013, 11:09 am
DILLIGASDAVE wrote:Some guys try to do everything with just the 4-link because of their adjustability, forgetting that air pressure & shock adjustments are also usable tools to add into the mix as well.
I have seen where some guys absolutely refuse to play with air pressure numbers just because they have a "favorite" pressure number that they have always used forever, and ever (and they aint gona change now).
Trust me we were throwing everything at it. I think the key was the guys who were working with it are big tire guys.It had a lot of issues first time out and they fixed all of them except for getting it hooked up. I knew this was going to be a challenge. There is not alot of people around here to consult with. Esp. at the track.
We found some things I need to change. I will get that done and get her back to the track. I am very persistant if nothing else. I'm open to suggestions. I need to get some photo's of the susp. up so you can have a better idea of what I'm working with.
A little shout to Keith F and Ted at Engine systems. The motor has been flawless. A very nice piece.
dr's wife racing
dr's wife racing
Post  richter69 November 12th 2013, 1:06 pm
Dave C. wrote:Gettin ready to buy shocks myself. What brand are you buying?
your DA Afcos are ordered lol
Post  whatbumper November 12th 2013, 1:55 pm
yellowhorse7 wrote:
whatbumper wrote:
dr's wife racing wrote:
whatbumper wrote:Most guys that set up true 4-links only know how to set them up for slicks.  way too much wheel speed usually.
I think that is the case here. They got every thing going streight, just no bite.  I do think new shocks on both ends will help.
If you're ready for some top of the line stuff just let me know.  Very Happy
Just don't sell him santhruffs. Not a fan. Good DA Afcos and he can send them to Menscer if need be
Cool
I wonder where I get my stuff from?
Post  yellowhorse7 November 12th 2013, 3:54 pm
Cool
Perfect
yellowhorse7
yellowhorse7
A few spy shots - Page 5 Empty A few pictures
Post  dr's wife racing November 16th 2013, 9:33 pm
Here are a few pictures of the suspension setup I'm working with.  I'm planning on changing to Afco Big Guns shocks on the rear.
A few spy shots - Page 5 HPIM1221
A few spy shots - Page 5 HPIM1222
A few spy shots - Page 5 HPIM1223
A few spy shots - Page 5 HPIM1225
A few spy shots - Page 5 HPIM1226
A few spy shots - Page 5 HPIM1227
dr's wife racing
dr's wife racing
Post  yellowhorse7 November 16th 2013, 11:43 pm
How old and how many passes on the rear tires?
yellowhorse7
yellowhorse7
Post  DILLIGASDAVE November 17th 2013, 5:39 am
Most any other brand drag shock is gonna be better than the Aldan Eagles on the car now.
Post  Wheelie58 November 17th 2013, 7:06 am
[quote="dr's wife racing"]
Glad to hear that the mill is still happy.
Thank you .
Keith
Wheelie58
Wheelie58
Post  dr's wife racing November 17th 2013, 11:36 am
bbf-falcon wrote:[quote="dr's wife rac.
Anybody want to guess the wt. on the pig?
2640 w/u in it.Smile
    Much higher This car is all steel only lexan is door glass
3220 with driver???????
It is 3085 lbs race ready with my over wt self in it.
dr's wife racing
dr's wife racing
Post  dr's wife racing November 17th 2013, 11:44 am
Tony the tires are about 2 yrs old. They only have the few test pass's I've put on them. They have been kept clean, stored inside out of the light but I consider them suspect. I plan on having a new set on it for the spring. I'm going to try and clean up any thing that is questionable over the winter. Do you think afco big guns are a good choice ?
I had plans to up grade the induction but I guess that budget will go to the suspension. No need to try and up the power when you can't use what you have.
dr's wife racing
dr's wife racing
Post  richter69 November 17th 2013, 11:57 am
looks like plenty of room for some tank tracks.........
Post  whatbumper November 17th 2013, 12:30 pm
Afco big guns are great when valved correctly. The afco fronts are cool too but each are pricey.
Post  yellowhorse7 November 17th 2013, 1:24 pm
dr's wife racing wrote:Tony the tires are about 2 yrs old. They only have the few test pass's I've put on them. They have been kept clean, stored inside out of the light but I consider them suspect. I plan on having a new set on it for the spring. I'm going to try and clean up any thing that is questionable over the winter. Do you think afco big guns are a good choice ?
Doesn't matter how they are stored. Tires are junk. Big Guns are great shocks. Get with Whatbumper and see what he can do for you. I believe he may be a dealer and I think has a contact with the shock nerd.
I'll tell you the same thing any other suspension guy will tell you. When you deal with big power and small contact patch, wear parts are CRITICAL for consistency. Tires must be fresh, springs must be tight, no binding anywhere, burn out and stage consistent, etc.
yellowhorse7
yellowhorse7
Post  dr's wife racing November 17th 2013, 2:30 pm
I agree with everything you said there Tony. That was the reason for the trip to the chassis shop. Everything is tight with the right shoulder  bolt's thru out. They found no bind. in it.We put new 130 lb springs. They are big tire guys but they are good on four links. They didn't pretend to be radial guys. I still think it was money well spent to get it all squared and running in a line.
We have to do a lot of work on getting the driver consistent. He's old,fat,cranky and don't see too good:lol:
dr's wife racing
dr's wife racing
Post  dr's wife racing November 17th 2013, 7:46 pm
richter69 wrote:looks like plenty of room for some tank tracks.........
There is room for some pretty big tracks under there. That is one reason I bought the car. I really want to make this radial deal work.
dr's wife racing
dr's wife racing
Post  whatbumper November 17th 2013, 11:35 pm
You have a very good foundation. There is a lot of information that most 4-link guys don't know when it comes to radials. Wheel speed is easy to work with, dead hooking without breaking stuff is more challenging. Smile
