A few spy shots
+20
Larry T
bigjohn2007
Dave C.
79ford pickup
Wheelie58
61coon
56Tbird
Barney
dr's wife racing
yellowhorse7
24 posters
Page 4 of 5
Page 4 of 5 • 1, 2, 3, 4, 5
Finally Ready
Plan to take her to track Sat. for some shake down runs. Has been a long time coming!
Re: A few spy shots
Video!
Re: A few spy shots
What track, Ward?dr's wife racing wrote:Plan to take her to track Sat. for some shake down runs. Has been a long time coming!
maverick- BBF CONTRIBUTOR
Re: A few spy shots
put the spurs to it Ward! and GOOD LUCK.........
Re: A few spy shots
Going to Holly springs, Miss. They are haveing a grudge race there tomorrow. It wont be hard to get yrack time. I'm just going to ride. Leaving the juice and lines at home so I won't be tempted. I'll do my best to get the go pro and some video shots. Man it has been a long time coming! We ran into some issues getting the shifter to work in final test last night but found out we had it set up wrong in the power grid.maverick wrote:What track, Ward?dr's wife racing wrote:Plan to take her to track Sat. for some shake down runs. Has been a long time coming!
Re: A few spy shots
update...................
Re: A few spy shots
[quote="cool40"]update...................[/quote
X2
X2
res0rli9- BBF CONTRIBUTOR
up date
We made it to the track yesterday. Things went well for a first time out. The motor ran great. flawless all day temp. in 180 deg. range all day. Oil pressure was good. It is a torque monster.Turned all the way to 6200 rpm one time! Was esp impressed with it since thise entire build is a NOS build.NOS coverter,gears are 3.60's, nos cam. There was no NOS in sight. Every thing on the car worked the way it should as far as elect, brakes, ign. ect . We missed the susp set up badly it stayed on the bumper for the entire day. I have not worked with radials on a car like this before. But it hooked. We didn't make much progerss adjusting it at the track. Best run was a 6.08 and MPH was in the low 120's and I was not gettig to full throttle untill about 300 ft. Pull's like a bear on the far end. I have no iIdea what the car will run. We brought every thing back home safe and in one piece. It sure felt good to get back in a car, even one that acted like that. I have a starting point. I know some things I need to do to help it.Then it is off to let some one who knows what they ar doing it set the suspension. Numbers should improve dramaticaly.
Re: A few spy shots
sounds like a beast. Glad to see it come together for you. It was all over your shop in pieces when I saw it!
jbozzelle- Posts : 3705
Re: A few spy shots
Bad thing is I hadn't cleaned the shop good since you were there. Been out there this morning cleaning it is amazing what I've found so far. I've worked hard on it. Have a couple of friends who have helped me alot. Would have been better off taking it to a chassis man to set it up first but after all that work I had to try it my way! Even though it didn't work that great I'm still proud of it.
Re: A few spy shots
We didn't thrash on my car alot. We had my buddies grudge car and was locked into a couple of races. We won both. It helps pay the bills if can win a few !! The other car was fussy to so we spent a good bit of time getting it where it needed to be. It ran good when the time come.
Re: A few spy shots
How's it sit now? SS or ladder bar ?dr's wife racing wrote:We made it to the track yesterday. Things went well for a first time out. The motor ran great. flawless all day temp. in 180 deg. range all day. Oil pressure was good. It is a torque monster.Turned all the way to 6200 rpm one time! Was esp impressed with it since thise entire build is a NOS build.NOS coverter,gears are 3.60's, nos cam. There was no NOS in sight. Every thing on the car worked the way it should as far as elect, brakes, ign. ect . We missed the susp set up badly it stayed on the bumper for the entire day. I have not worked with radials on a car like this before. But it hooked. We didn't make much progerss adjusting it at the track. Best run was a 6.08 and MPH was in the low 120's and I was not gettig to full throttle untill about 300 ft. Pull's like a bear on the far end. I have no iIdea what the car will run. We brought every thing back home safe and in one piece. It sure felt good to get back in a car, even one that acted like that. I have a starting point. I know some things I need to do to help it.Then it is off to let some one who knows what they ar doing it set the suspension. Numbers should improve dramaticaly.
yellowhorse7- Posts : 1382
Re: A few spy shots
Good deal Ward
Re: A few spy shots
This one is a true four link set up. The chassis is a "limited street" chassis. Wish I had you her to help me set it up. I knew it was a shot in the dark with me setting it cause I don't what I'm doing with a four link. Esp from scratch. Time is getting short and it was important to me to know that every thing else worked on the car. It was also important for me to get back in the seat.yellowhorse7 wrote:How's it sit now? SS or ladder bar ?dr's wife racing wrote:We made it to the track yesterday. Things went well for a first time out. The motor ran great. flawless all day temp. in 180 deg. range all day. Oil pressure was good. It is a torque monster.Turned all the way to 6200 rpm one time! Was esp impressed with it since thise entire build is a NOS build.NOS coverter,gears are 3.60's, nos cam. There was no NOS in sight. Every thing on the car worked the way it should as far as elect, brakes, ign. ect . We missed the susp set up badly it stayed on the bumper for the entire day. I have not worked with radials on a car like this before. But it hooked. We didn't make much progerss adjusting it at the track. Best run was a 6.08 and MPH was in the low 120's and I was not gettig to full throttle untill about 300 ft. Pull's like a bear on the far end. I have no iIdea what the car will run. We brought every thing back home safe and in one piece. It sure felt good to get back in a car, even one that acted like that. I have a starting point. I know some things I need to do to help it.Then it is off to let some one who knows what they ar doing it set the suspension. Numbers should improve dramaticaly.
Re: A few spy shots
Check ur PM's buddr's wife racing wrote:This one is a true four link set up. The chassis is a "limited street" chassis. Wish I had you her to help me set it up. I knew it was a shot in the dark with me setting it cause I don't what I'm doing with a four link. Esp from scratch. Time is getting short and it was important to me to know that every thing else worked on the car. It was also important for me to get back in the seat.yellowhorse7 wrote:How's it sit now? SS or ladder bar ?dr's wife racing wrote:We made it to the track yesterday. Things went well for a first time out. The motor ran great. flawless all day temp. in 180 deg. range all day. Oil pressure was good. It is a torque monster.Turned all the way to 6200 rpm one time! Was esp impressed with it since thise entire build is a NOS build.NOS coverter,gears are 3.60's, nos cam. There was no NOS in sight. Every thing on the car worked the way it should as far as elect, brakes, ign. ect . We missed the susp set up badly it stayed on the bumper for the entire day. I have not worked with radials on a car like this before. But it hooked. We didn't make much progerss adjusting it at the track. Best run was a 6.08 and MPH was in the low 120's and I was not gettig to full throttle untill about 300 ft. Pull's like a bear on the far end. I have no iIdea what the car will run. We brought every thing back home safe and in one piece. It sure felt good to get back in a car, even one that acted like that. I have a starting point. I know some things I need to do to help it.Then it is off to let some one who knows what they ar doing it set the suspension. Numbers should improve dramaticaly.
Re: A few spy shots
Still struggling with the radials. Decicded thatmy only hope to get the car back to the track this yr was to take it to someone. I took it to a local chassis guy and had a antiroll bar installed. Had him do a chassis set up on it while it was there. It helped a great deal car drives mch better down the track but it would not get ahold of the starting line. Most of the time just blew the tires off. Best it ran was a 5.75 at 125 mph on foot brake. It spun at about 100 feet that pass and there was a good bit of peddling on that pass. Think I'm done for the yr now.
I think I'm going to put new shocks all the way around. and restart in the spring. I'm just not sure I have the stuff under it to get the job done. Tony I'll get you some photo's & info on it.
Anybody want to guess the wt. on the pig?
David had the Bird dialed in on the 5.30 mark. Went a few rounds before being bit by a case of the red eye.
Re: A few spy shots
Most guys that set up true 4-links only know how to set them up for slicks. way too much wheel speed usually.
whatbumper- Posts : 3024
Re: A few spy shots
[quote="dr's wife rac.
[/quote]
2640 w/u in it.
[/quote]
2640 w/u in it.
Re: A few spy shots
bbf-falcon wrote:[quote="dr's wife rac.
2640 w/u in it. [/quote] Much higher Tis car is all steel only lexan is door glass
Re: A few spy shots
I think that is the case here. They got every thing going streight, just no bite. I do think new shocks on both ends will help.whatbumper wrote:Most guys that set up true 4-links only know how to set them up for slicks. way too much wheel speed usually.
Re: A few spy shots
Gettin ready to buy shocks myself. What brand are you buying?
Dave C.- Posts : 1268
Re: A few spy shots
If you're ready for some top of the line stuff just let me know.dr's wife racing wrote:I think that is the case here. They got every thing going streight, just no bite. I do think new shocks on both ends will help.whatbumper wrote:Most guys that set up true 4-links only know how to set them up for slicks. way too much wheel speed usually.
Re: A few spy shots
Just don't sell him santhruffs. Not a fan. Good DA Afcos and he can send them to Menscer if need bewhatbumper wrote:If you're ready for some top of the line stuff just let me know.dr's wife racing wrote:I think that is the case here. They got every thing going streight, just no bite. I do think new shocks on both ends will help.whatbumper wrote:Most guys that set up true 4-links only know how to set them up for slicks. way too much wheel speed usually.
Re: A few spy shots
Much higher Tis car is all steel only lexan is door glassdr's wife racing wrote:bbf-falcon wrote:[quote="dr's wife rac.
2640 w/u in it.
3220 with driver???????
Re: A few spy shots
Some guys try to do everything with just the 4-link because of their adjustability, forgetting that air pressure & shock adjustments are also usable tools to add into the mix as well.
I have seen where some guys absolutely refuse to play with air pressure numbers just because they have a "favorite" pressure number that they have always used forever, and ever (and they aint gona change now).
DILLIGASDAVE- Posts : 2262
» Cobralcon Build
» Car Girl Calender Shots
» Just some shots of Edelbrock RPM Air-Gap 7566 - and my older Victor Bigblock
Page 4 of 5
