First passes with the 514
+14
Nastynotch
droppedf100
460pulling
quick 52
bluef100fe
LovesDemCubes
Dave C.
tfsbbf466
18 posters
Page 3 of 3 Previous  1, 2, 3
First passes with the 514 - Page 3 Empty Re: First passes with the 514
Post  whitefield October 29th 2013, 11:20 am
tfsbbf466 wrote:I changed the converter first then the cam.
Crank is cast
How was the track prep and air temp after the converter change as a comparison to when you ran it after the cam change ?
Did you jet the 850 after converter and cam change?
By reading your build I maybe over carb'd for my 466 and my 393W.
whitefield
whitefield
Post  tfsbbf466 October 29th 2013, 3:49 pm
Crank is cast
The nights were similar and it hooks everytime so that is a non issue. It lost .10 with the tighter converter but gained a mph. Cam swap at first didn't pick up so I tightened the lash and switch my motor and nitrous pumps bc I only had a blue pump running the motor and it picked up almost a tenth and 2mph over my best. Nitrous times picked up even more which made me way happy. When I went from the 73 to the 82 jet I gained less the 1 tenth a 1mph so I assume the carb and or headers are still holding me back some.
tfsbbf466
Post  whitefield October 29th 2013, 5:32 pm
tfsbbf466 wrote:
Crank is cast
Dang it man !What have you got for traction ? That's turning it up and turning it on !bounce bounce bounce
whitefield
whitefield
Post  IDT-572 October 29th 2013, 8:45 pm
The cam change will show even more when you get the carb and headers right...............Cool
Post  tfsbbf466 October 30th 2013, 12:06 am
whitefield wrote:Dang it man !What have you got for traction ? That's turning it up and turning it on !bounce bounce bounce
Thanks man. Suspension is pretty simple. Lowered I beams up front with stock coils and 90/10s. Stock leafs with the rear on top of springs with caltrac bars and I have the rear shocks mounted behind the rear. Cheap Rancho single adjust.
I wanted to do a carb before the years up but I need to get my daily driver fixed. I've been driving this truck daily for the last 3 months. I'll be happy with another 9 second pass to back it up. Next year I'll make some changes.
tfsbbf466
Post  Nastynotch October 30th 2013, 6:03 am
tfsbbf466 wrote: I've been driving this truck daily for the last 3 months.
That's great that you can do that. What kind of mpg does it get, just out of curiosity?
Nastynotch
Post  tfsbbf466 October 30th 2013, 7:24 am
Never really checked but it's not good lol. Luckily I don't have to drive it too far on a regular basis. Definitely isn't my first choice for a daily but it does ok and cruises nice on the highway with the tighter converter, 3.70s and a near 30" tire.
tfsbbf466
