Convert bolts?
Convert bolts? Empty Convert bolts?
Post  jones April 28th 2015, 9:19 am
I got a converter from UC? The converter is a turbo 400 converted to a C6. It appears the converter flanges are tapped for bolts. Where can I find these bolts at
jones
Convert bolts? Empty Re: Convert bolts?
Post  Copperhead April 28th 2015, 11:22 am
If I'm not mistaken,.......the bolts are a 7/16-20".
AND,....
FWIW,..... 7/16" seem to be a little more difficult to find, as most places like Lowes, Home Depot, & Tractor Supply jump from 3/8" to 1/2".
Your best bet is a local Fastener company that specializes in industrial supplies,.......
If this is not an option, you have online places like McMaster Carr, Grainger, MSC, Fastenal and etc,......
Copperhead
Copperhead
Post  jones April 28th 2015, 11:45 am
I'd rather have a higher quality bolt, I'm going to look into ARP for sure but who are the other performance bolt manufacturers.
jones
Post  69F100 April 28th 2015, 12:24 pm
Grade 8 bolts came with my converter from PTC they are fine tread I know Fastenal carry them they are 7/16 don't remember the length
Post  Copperhead April 28th 2015, 1:06 pm
jones wrote:I'd rather have a higher quality bolt, I'm going to look into ARP for sure but who are the other performance bolt manufacturers.
Grade 8 is plenty good enough.
Don't get hung up on the ARP hype.
Don't get me wrong,.......I have a bunch of ARP fasteners in my rig,...... BUT,... for the most part, it's overkill. ARP stuff is great for Main & Head Studs,....as well as Rod Bolts, BUT,.......other than that,..... standard Grade 8 (OR,... even Grade 9) are perfectly fine.
Copperhead
Copperhead
Post  maverick April 28th 2015, 2:49 pm
Got any extra flywheel bolts lying around?
Post  cool40 April 28th 2015, 10:41 pm
maverick wrote:Got any extra flywheel bolts lying around?
Idea exactly what i was thinking!
Post  jones April 28th 2015, 11:47 pm
So those are the same sizes?
jones
Post  maverick April 29th 2015, 8:15 am
Yup.
Post  jones April 29th 2015, 8:51 am
While in the topic of bolts, anyone know where I can find the factory style bolts? I'd rather use those than have to use a washer.
jones
Post  maverick April 29th 2015, 9:04 am
jones wrote:While in the topic of bolts, anyone know where I can find the factory style bolts? I'd rather use those than have to use a washer.
Any dealership probably has 'em but they ain't free.  Look in the junk yards.  And don't be stuck on bolts from a BBF...Most common U.S. made stuff used fine thread 7/16" bolts on their flywheels. The damn things are everywhere.   Also, no harm in adding a grade 8 flatwasher...and maybe a lil' dab of blue Loctite.
If you go boneyard shopping, put a 7/16 fine thread nut in your pocket. It's easy to mistake a metric bolt for what you want if it's been removed from the engine.
Post  jones April 29th 2015, 11:05 am
I have always used red loctite on the flex plate bolts.
jones
Post  jones April 29th 2015, 11:12 am
Here is a picture of the converter. It's hard to tell in the photo and I will check but they almost look like course threads. I hope those welds hold! LoL
Convert bolts? 164910BF-4246-4128-98FE-7DE674264317_zpsxoxrxp3x
jones
Post  jones April 29th 2015, 11:41 am
This is a picture of the gear box and transmission without the extension. The gear box is .875 away from bolting to the extension. I will have to cut the output shaft .900 or make a spacer .900 thick. I'm pretty sure I am going to cut a spacer out on the water jet and finish it on the lathe.
Convert bolts? D79988C0-C631-4C3B-971C-1B1BDF1CD66F_zpsfwdrg4gn
jones
Post  jones April 29th 2015, 11:44 am
I'm also trying to decide if I want to use 1350 yoke's , 1410 or 1480's. If I had to guess on what would break first I say the transmission output shaft.
jones
Post  maverick April 29th 2015, 11:51 am
On a deal like that, U-joint alignment is gonna be key to keeping all the parts in place.
Post  jones April 29th 2015, 11:55 am
FYI,
The bolts I said I was look for are found. They are called "flange bolts" or "frame bolts".
jones
Post  jones May 2nd 2015, 11:27 pm
I wanted to say that I am really pleased with Lenny, he read my post and gave me a phone call to answer my question! I can't wait to get this project driving.
jones
