93 F150 528cu project build
+28
Big block fox 339
Northwest outlaw
ThndrChkn
96Mustang460cid
blown473
blown86hallet
Copperhead
70bbftorino
Greg_P
D. Sea
racerk_2000
'65 T-BOLT
longroofracer
droppedf100
sixtynineford
Blue Oval Forever
jones
32 posters
Page 3 of 6 Previous  1, 2, 3, 4, 5, 6  Next
93 F150 528cu project build - Page 3 Empty Re: 93 F150 528cu project build
Post  jones February 10th 2010, 9:04 am
The fuel gauge might have still worked but it now has a fuel cell with a Gm sending unit. I figure that the computer didn't have anything to do with the turn signals. Just have to see whats going wrong where for nothing on the column to work.
jones
Post  jasonf February 10th 2010, 10:36 am
L&L Products makes the shortest right angle oil filter adapter I could find when I swapped into my 85. On the oil pan drain plug is there enough clearance that you could run an AN line from the front sump to the rear sump so it could just drain back?
Post  jones February 10th 2010, 12:59 pm
Ended up not having to use the oil filter adapter. All I had to do was trim an inch or two from the crossmember and the Motorcraft oil filter fits great. (The cut looks crappy but you can only cut so much of a curved notch with a straight 6" cut off wheel!)
I should have enough room to use some type of tube to carry the oil away from the front sump.
jones
Post  droppedf100 February 15th 2010, 10:25 pm
My dads 95 still has the computer in it i believe but everything works. A/C, gauges, tach, pw, ignition (MSD). It even has the stock column shifter and cable hooked up to the C6. It has all the wiring up to the engine harness and everything is cut out except the a/c, gauges, and wires for tach. Ill get pictures if you want. Its not the cleanest set-up and im sure alot could be eliminated still but I havent really messes with it. Even the Aeromotive fuel pump turns on with the key. We use the front/rear tank switch to turn it on and off.
droppedf100
droppedf100
Post  jones February 16th 2010, 8:54 am
droppedf100 wrote:My dads 95 still has the computer in it i believe but everything works. A/C, gauges, tach, pw, ignition (MSD). It even has the stock column shifter and cable hooked up to the C6. It has all the wiring up to the engine harness and everything is cut out except the a/c, gauges, and wires for tach. Ill get pictures if you want. Its not the cleanest set-up and im sure alot could be eliminated still but I havent really messes with it. Even the Aeromotive fuel pump turns on with the key. We use the front/rear tank switch to turn it on and off.
That is how I would like to do it. (Except for the column shifter.) I honestly haven't dove into a wiring schematic yet, so it might not be as bad as I am thinking. Hopefully I can work on it this weekend.
jones
Post  Copperhead February 16th 2010, 11:28 am
jones wrote:Finished the transmission crossmember.
93 F150 528cu project build - Page 3 003-3
93 F150 528cu project build - Page 3 001-2
93 F150 528cu project build - Page 3 002-2
Hey Jones,
The crossmember looks good, but you're probably going to run into the same problem as me when I first did a BB swap on mine. If you plan on running long tube headers, then they'll proabably come out smack in the middle of the crossmember.
You can either put an s-bend just after the collector (which I don't recommend) or you can do what I did and v-shape the tubing for the crossmember. Mine now bolts to the upper most portion of the frame.
Copperhead
Copperhead
Post  jones February 16th 2010, 1:24 pm
I thought about that after I got finished. Right now I am using midlength headers and should be able to make a straight shot bellow the cross member. If I run into this problem I figure I'll take some dom to a machine shop and try to get them to bend some "humps" as tight as they can. Or like you said, hang it from the top and have the tube bent to drop bellow the mount then back up.
Speaking of exhaust, I have to find some good steel V-band connectors.
jones
Post  blown86hallet March 8th 2010, 12:30 pm
Jones.
In our early 6.7L builds the turbo piston was to small so we had the run a remote oil line to the center section, bla bla bla.. anyway, we used PETERSON in line filters. I have 20 - 30 of these filters. Just letting you know, YOU have one here if you would like one? Cheap....!
adam
blown86hallet
blown86hallet
Post  jones March 8th 2010, 12:37 pm
blown86hallet wrote:Jones.
adam
Thank you man, look for a PM!
jones
Post  jones March 8th 2010, 12:50 pm
Ok, I know I haven't posted anything in a while. Main update is the engine package has changed for the better! As for exactly what and how much,,,,, don't be too surprised!!! I have changed the entire engine one time already! Laughing Who knows what I am up to now, sometimes I don't even know! Laughing
Whenever I get a chance to do something I'll post!
jones
Post  jones March 13th 2010, 11:31 pm
I finally got the fuel cell mounted so I could move on to something else. I'll come back later and remove the aluminum tabs that came welded on the fuel cell. use 1/16 x 1" steel for the straps, sanded, primed and painted cast aluminum for now. I place some rubber strips between the straps and fuel cell. The rubber makes the straps bow a little but the fuel cell is tight and not moving. I guess it looks ok. The tank is a Summit 15gal with fuel level sender. I was going to mount it under the bed and use the stock fuel door, but it just hung to low.
93 F150 528cu project build - Page 3 012-2
jones
Post  '65 T-BOLT March 13th 2010, 11:45 pm
looks good enough to me! I would be happy with that install. Even thou the straps are bowed a little. Maybe could have used 4 little spacers under the factory tabs on the cell and bolted tit to the bed that way! ..just a thought!
'65 T-BOLT
'65 T-BOLT
Post  jones March 13th 2010, 11:50 pm
'65 T-BOLT wrote:looks good enough to me! I would be happy with that install. Even thou the straps are bowed a little. Maybe could have used 4 little spacers under the factory tabs on the cell and bolted tit to the bed that way! ..just a thought!
Wouldn't pass tech, plus the tabs are really weak. I would have mounted the straps right over the tabs, but if you notice the return and vent bung is in the way.
jones
Post  '65 T-BOLT March 13th 2010, 11:54 pm
Thanks for the insite! I was not aware that it would not pass tech. I know you said that the tabs are week...but what if you had some 3/4 square tube welded to the frame under the bed? my friend has a 65 stang, square tube chassis and his dad used nut certs in the crossmembers for his cell...car not finished, so not tech'ed
'65 T-BOLT
'65 T-BOLT
Post  jones March 14th 2010, 12:14 am
I figured this would be the easiest and lightest way to do it. I am going to add a aluminum battery box on the rear passanger side. I think that would make it look a little better.
The bed is going to get another paint job or spray in bed liner. I have a handful of holes to weld in the bed floor, but for right now it's done! Very Happy
jones
Post  droppedf100 March 14th 2010, 1:39 am
Why didnt you just sump the stock rear tank?
droppedf100
droppedf100
Post  jones March 14th 2010, 2:01 pm
Didn't want to mess with it. This has the foam and I don't have to go in circles with buying a new fuel tank then welding up and sealing it.
jones
Post  droppedf100 March 14th 2010, 8:25 pm
I had my stock tank boiled out and had them weld my sump in for 100 bucks a couple years ago. To each his own but for my truck I like to use the stock gas door and I like the bed open.
Did you figure out the wiring yet?
droppedf100
droppedf100
Post  jones March 14th 2010, 8:33 pm
droppedf100 wrote:I had my stock tank boiled out and had them weld my sump in for 100 bucks a couple years ago. To each his own but for my truck I like to use the stock gas door and I like the bed open.
Well this truck didn't come with a gas tank so I had no clue what it would have taken to put one in. I am going to put a soft cover over the bed, battery relocation kit and nitrous bottles.
I gave up on the wiring for now, until I just have to have it done.
jones
Post  bruno March 14th 2010, 8:40 pm
bring the truck to me and we will wire it up Wink
http://WWW.CKRME.COM
Post  '65 T-BOLT March 14th 2010, 9:51 pm
and put a killer sound system it it for you too!
'65 T-BOLT
'65 T-BOLT
Post  jones March 14th 2010, 11:23 pm
Don't be joking around, you might ended up with a truck on your property! Laughing
jones
Post  droppedf100 March 17th 2010, 1:26 am
LOL. Wish you were closer I could give you a hand. Im nowhere near an expert but I have had a ton of 92-96 trucks apart.
droppedf100
droppedf100
93 F150 528cu project build - Page 3 Empty nice truck
Post  blown473 March 18th 2010, 8:57 pm
Thats going to be nice when its done! Love the early Lightinings !! I have a gen 2 Lightining, its been a great truck. A big block early model should be a whole lot of fun!!
blown473
blown473
Post  jones March 18th 2010, 10:32 pm
Thanks,
jones
