AFR BBF Head
+49
glenevans
snuff98
jeffgfg
bigford632
Mark Laczo
Straubtech
6t6mustang
STR-LGL-70
The Mad Porter
Mark O'Neal
nickpohlaandp
XF-66
ED468
wayney
Hardy
tbirdmike
68galaxie
Gary Blair
carlthomasd
fastashley
jones
QtrWarrior
Darrin Gorham
Coupe Devil
torino501
Carl
53 posters
Page 8 of 12
Page 8 of 12 • 1, 2, 3 ... 7, 8, 9, 10, 11, 12
Re: AFR BBF Head
results
999.3 @ 6,500 RPM
1,007 @ 6,600 RPM
1,009 @ 6,700 RPM
1,013 @ 6,800 RPM
1,010 @ 6,900 RPM
1,011 @ 7,000 RPM
1,005 @ 7,100 RPM
The 315 stuff is good....real good!
999.3 @ 6,500 RPM
1,007 @ 6,600 RPM
1,009 @ 6,700 RPM
1,013 @ 6,800 RPM
1,010 @ 6,900 RPM
1,011 @ 7,000 RPM
1,005 @ 7,100 RPM
Re: AFR BBF Head
Damn!!! Nice numbers Lem and Phillip.
68formalGT- Posts : 865
Gary Blair likes this post
Re: AFR BBF Head
Nice build Lem, can you give any details? Are the heads out of the box cnc ported, or did you rub on them?
Mike R- Posts : 1381
Re: AFR BBF Head
Gary Blair wrote:What cam and compression? Fuel?
It's Phillip's compression ratio and fuel so, you'd have to ask him.
It's my cam.
Re: AFR BBF Head
Lem Evans wrote:results
999.3 @ 6,500 RPM
1,007 @ 6,600 RPM
1,009 @ 6,700 RPM
1,013 @ 6,800 RPM
1,010 @ 6,900 RPM
1,011 @ 7,000 RPM
1,005 @ 7,100 RPM
Very nice build gentlemen !!!
Guess that answers the "Will they support 1000 hp out of the box question" ...
...and at 6,500 rpm no less.
There is most certainly some more there by working the as delivered AFR intake.
Again nice build !!!
S
Last edited by The Mad Porter on February 19th 2018, 10:02 pm; edited 1 time in total
Re: AFR BBF Head
The cam is a bit different than usual.
Re: AFR BBF Head
"The 315 stuff is good....real good!"
"The cam is a bit different than usual"
Once again, a display of what is possible when the right combination of knowledge and ability is applied to ones craft.
FalconEh- Posts : 1448
Re: AFR BBF Head
How was the torque Lem?
Re: AFR BBF Head
68formalGT wrote:How was the torque Lem?
840 lbs ft to 843.1 between 5,100 RPM to 6,000 RPM .
Re: AFR BBF Head
Lem Evans wrote:68formalGT wrote:How was the torque Lem?
How did that compare to the 588" p-51 build you and Phillip did?
Re: AFR BBF Head
Nice work guys. Were the heads and intake bolted on as is or did you do some port work on them?
Thanks,
Butch
Thanks,
Butch
bigford632- Posts : 42
Re: AFR BBF Head
Got pleanty of good heads available, now we just need some better intakes to get some RPM to make more power.
Re: AFR BBF Head
bigford632 wrote:Nice work guys. Were the heads and intake bolted on as is or did you do some port work on them?
Thanks,
Butch
The head and manifold castings were not modified.
Re: AFR BBF Head
Clearly a bogus marketing ploy.
(joking)
Impressive work. Congratulations!
(joking)
Carl- Posts : 284
Re: AFR BBF Head
Sounds like a great option for a really good bracket engine that does not have to turn high rpm.
snuff98- Posts : 245
Re: AFR BBF Head
Considering the oil pressure....who can correctly guess the inches of Hg the vacuum pump was producing?
Re: AFR BBF Head
I just re-read through this build and maybe I missed it, but what is the bore & stroke?
Thanks, Sheldon
Thanks, Sheldon
STR-LGL-70- Posts : 223
Re: AFR BBF Head
Nice flat torque curve Lem. Any details of the combo ? I know it has the new AFR heads on it.
John Myrick- BBF CONTRIBUTOR
Re: AFR BBF Head
I was wondering the same thing. ok I just saw it on Facebook 598.STR-LGL-70 wrote:I just re-read through this build and maybe I missed it, but what is the bore & stroke?
Thanks, Sheldon
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» the best head
» P51 Head HP gain after head port
» the best head
Page 8 of 12
