My build, my Fox transformation....lotsa pics
+34
Jetman
Goblin
jc10000rpm
2fox
nitrous.f
D's557BBF
yellowhorse7
cobra tom
JACKAZZFLATZ
quick 52
72mav
bb429power
'65 T-BOLT
GTmustang
nuclearcobra
D. Sea
Northwest outlaw
bigblockfox468
38 posters
Page 3 of 7
Page 3 of 7 • 1, 2, 3, 4, 5, 6, 7
Re: My build, my Fox transformation....lotsa pics
Lookin Good Mike,that horse will be eatin by spring
That's cool Mike, it looks like were at the same step in our engine builds.
Bet a huuunderd bucks I can beat you Will you be going to the friday night heads up at milan with that at all? I saw a red stang like yours pull the wheels at the last one I went to. Then he came down in the left lane with a broken suspension part and veered back into the right lane. The brakes went out and he hit the wall
bb429power- Posts : 3129
bbf-falcon wrote:Lookin Good Mike,that horse will be eatin by spring
Thanks Rick. I'd like to see it eatin some oats before I bed it fore winter We'll see
You're on Justin By the way it's ORANGE Just funnin
I'll be at the track Oct. 23. We would have to bracket race, my heavy truck wont go nearly as fast as your car will.bigblockfox468 wrote:bb429power wrote:
it gonna boogie...........
richter69 wrote:it gonna boogie...........
boogie woogie
D. Sea- Posts : 2768
Better to say..."on" than "in"IDT-572 wrote:Your doing a good job Mike............
Might as well fix all the problems now, so the won't bite you in the butt later.............
Looking good. I like how you dropped the weight off the nose by getting rid of the radiator support. How much did that weigh?
jbozzelle- Posts : 3705
jbozzelle wrote:Looking good. I like how you dropped the weight off the nose by getting rid of the radiator support. How much did that weigh?
Don't know John. I bought the car with a BBF already in it and they did that work and I'm just..........lets say I'm tweaking it now Thanks
Blake tells me were not too far from making this bitch strain on the dyno I can't wait
Here's a few shots from the Snake showing off his magic on the ports
Flow numbers
Intake No back cut 30 degree .090 wide back cut exhaust
Cfm gain
.100 87 84 -3 72.7
.200 148 170.4 +22.4 117
.300 210.5 254 +43.5 154
.400 279.8 356 +76.2 182
.500 336.8 358 +21.2 207
.550 ____ 366 ___
.600 367 367.3 +.3 222
.700 377.2 358 -19.2 228
.800 233
20 cfm average gain .100 through.700
SF 600 Superflow
Exhaust flow with out pipe
Hope you guys can read this.............
Cfm gain
.100 87 84 -3 72.7
.550 ____ 366 ___
.800 233
SF 600 Superflow
I did the flow numbers in word document , nice rows and all lined up. I copied and pasted it and it comes out looking like crap............ Go figure.
2.200 valve no back cut
Intake
Before
.100 87
.200 148
.300 210.5
.400 279.8
.500 336.8
.550 -
.600 367
.700 377.2
2.200 w30* back cut
Intake
After
.100 84
.200 107.4
.300 254
.400 356
.500 358
.550 366
.600 367.4
.700 358
Exhaust
.100 72.7
.200 117
.300 154
.400 182
.500 207
.600 222
.700 228
.800 233
Intake
Before
.100 87
.200 148
.300 210.5
.400 279.8
.500 336.8
.550 -
.600 367
.700 377.2
2.200 w30* back cut
Intake
After
.100 84
.200 107.4
.300 254
.400 356
.500 358
.550 366
.600 367.4
.700 358
Exhaust
.100 72.7
.200 117
.300 154
.400 182
.500 207
.600 222
.700 228
.800 233
bigblockfox468 wrote:2.200 valve no back cut
Intake
Before
.100 87
.200 148
.300 210.5
.400 279.8
.500 336.8
.550 -
.600 367
.700 377.2
2.200 w30* back cut
Intake
After
.100 84
.200 107.4
.300 254
.400 356
.500 358
.550 366
.600 367.4
.700 358
Exhaust
.100 72.7
.200 117
.300 154
.400 182
.500 207
.600 222
.700 228
.800 233
Dang Mike your a genious...................
I know
Dyno time 10-30-10
I'll keep you posted with the results
Do not have any final dyno numbers because of the situation we had. If you're not sure what I mean check out my DYNO PARTY thread in General Discussion. I call tell you though it was making some nice #'s for low 6k pulls .
Here some pics
and yours truly playing with the distibutor
Here some pics
Well Blake has her ready to roll again He totally disassembled it and went over it with a fine tooth comb and didn't find any major issues or damage other than the rear main bearing suffered some damage when the dyno coupler let go.
So I'm very happy with that .
Not sure when we'll re-dyno but I will post results as soon as they are available. Wish us better luck this time
cool beans there Mike!...you don't need no luck....that was just a fluke!...shit happens! It will rock n roll next time!
'65 T-BOLT- Posts : 1464
We got the engine on the dyno last night, Made a short pull with the last jetting change from the last time. It made 708 @ 6000 rpm. These numbers may be off a number or two, Mike has the dyno sheets and will post them later.
I'm posting from memory.
After the tuning was all said and done we saw 751 Hp @ 6400 rpm and 681 Ft Lb. Torque @ 4900.
It had over 650 ft lb torque from 4500 through 5500 rpm and still held 616 at the Hp peak 6400.
In a world of high compression, max ported, big inch, solid roller camed engines, I was happy with the out come of this flat top , flat tappet, bowl blended, 528.
Good hp per dollar combo. The SCJ flat tappet heads that Lem sales and a good inexpensive flat tappet cam , cast crank, H beam rods, forged pistons. Killer bracket deal.
You don't have to turn it over the moon to make decent power.
I want to thank Mike for waiting on this engine. When he called me to do this deal, I told him I was way behind and would be a good while before I could get to it, then to add to it we had the problem on the dyno that set us back again. He never complained once and was very understanding through the whole deal.
I'm glad it all worked out well for him.
Cheers..Blake,good #s and a job well done.
res0rli9- BBF CONTRIBUTOR
Great combo Blake. Congrats.
That will last a LONG time if its maintained right. Like you said, a GREAT bracket motor.
Al
Al
72mav- Posts : 1081
nice job, and I'm REALLY diggin on the test stand....
138- Posts : 1593
» Just some pics of parts for my 557 fox build
» Turbo Mustang build pics
» My build.....not done yet, but damn close! lots of pics!
» Official 1974 F100 dragtruck build thread *pics added*
» Rear Wing fabed up (PICS) MORE PICS ADDED
Page 3 of 7
