P-51 headed 472 build... DYNOED
+10
The Pope
Larry Williams
ThndrChkn
D's557BBF
bigblockfox468
Ranch71460
14 posters
Page 2 of 2 Previous  1, 2
P-51 headed 472 build... DYNOED - Page 2 Empty Re: P-51 headed 472 build... DYNOED
Post  devildog July 14th 2010, 8:18 pm
Looks good....I like it..D
devildog
Post  Ranch71460 October 5th 2010, 11:38 pm
It was a long summer working out of town but I'm finally up and running.
I'm putting the 'Chero on a chassis dyno at Dynomotive http://dynomotive.ca/ tomorrow nite for some tuning, then it's off to the track Friday night.
The old A429 headed 466 put down 466 hp at the wheels last year with a best of 11.77 @ 115.35 mph at Race City last year.
This should do a little better eh:
P-51 headed 472 build... DYNOED - Page 2 Th_472running001
Ranch71460
Ranch71460
Post  nuclearcobra October 6th 2010, 1:56 am
I'd say Twisted Evil
nuclearcobra
nuclearcobra
Post  Ranch71460 October 8th 2010, 6:47 am
Put the 'Chero on the dyno last night at Dynomotive here in Calgary. http://dynomotive.ca/
My old A429's were max ported but there was a good gain with the P51's.
The Ranchero has a C6 prepped by Frank Merkl, 4000 stall Pro-West converter, 4:11 Detroit Locker, 28"x11" ET Streets.
The 472: 12:1 Diamond pistons, Comp solid roller with 110 LSA, 262/262 duration @ .050", .663/.663 lift , 1000cfm HP Holley,
MSD distributor &6AL, out of the box P51's and a mid 90's Taurus smog pump for evacuation.
We optimized the timing at 31 degrees @ 4000rpm.
Basically the same build as my 466 with new heads. It runs on 94 octane ethanol.
The dark lines are this year's pass vs the dyno pull on the 466.
The DA was about 5700 ft. last night.
I'm heading to the track tonight.
P-51 headed 472 build... DYNOED - Page 2 Dynoof472001
Ranch71460
Ranch71460
Post  Ranch71460 October 9th 2010, 11:50 am
My complete build:
D1VE block with Hyghflow Dynamics http://www.highflowdynamics.com/ block and oiling mods, bored .060" over, ARP main and head studs.
Stock internally balanced crank
Eagle H beam rods, stock length
Diamond flat top pistons http://www.bfevansraceparts.com/
Balanced reciprocating system
Clevite 77 main and rod bearings
extra wide cam bearings http://www.bfevansraceparts.com/
Kaase oil pump http://www.bfevansraceparts.com/
ARP oil pump drive shaft
windage tray
crank scraper
Kaase P51 heads c/w roller springs and titanium retainers, out of the box non ported http://www.bfevansraceparts.com/
Smith Brothers 3/8" push rods
Comp solid roller lifters
Comp cam #34-710-9, 110 degree LSA, duration 262/262 degrees @ .050", .663/.663" valve lift, double pinned
Comp stainless roller rockers - 1.7 ratio
JP Performance roller timing chain
Edelbrock Victor intake, worked on in the plenum
1000 cfm HP series Holley carb
MSD distributor and 6AL ignition
Meziere electric water pump
Mid 90's Taurus smog pump for crank case evacuation
Hooker 6115's - 1 7/8" primaries, 3 1/2" collectors
Ranch71460
Ranch71460
Post  devildog October 12th 2010, 9:41 pm
Well??????....How did the 19hp at the wheels do????......D
devildog
Post  Ranch71460 October 12th 2010, 11:19 pm
Not good. The air was about 5200 FT DA.
My first run I tried launching at about 2000 (4000 stall converter)... 1.82 sixty foot, 12.02 @ 113.32mph.
Second run... I foot braked it over 3000 until the car was starting to push through the lights. The result was
my best ever 60 Ft - 1.71 but I only went 11.90 @ 113.2 mph.
The best time with the old motor was a 1.77 60 ft. with an 11.77@ 115.35 mph in my 3775 lb car +me at 210 lbs.
The diagnosis from people who worked with my motor previously is my converter is not working right.
I talked with Lenny @ UCC today for a solution.
Our track is done for the season now.
Ranch71460
Ranch71460
Post  1Bad91 October 13th 2010, 9:54 am
Bummer, you get it right next season. Nice build by the way.
1Bad91
1Bad91
Post  devildog October 13th 2010, 2:12 pm
Wondering how the whole power curve was affected by the heads???? Going to take some tweaking to figure out how to take advantage of those heads. Changing something major in your combination invariably causes something else to be changed. How are you shift points compared to before? Wish your track was not closing already..............D
devildog
Post  dfree383 October 13th 2010, 2:34 pm
A new Cam and Convertor sounds like where you need to go next.
Post  devildog October 17th 2010, 8:53 pm
Here is my take....heads have the potential to make the car quicker.....if you can figure out how to make them work on your particular combination......it may not be simple........Spending money does not guarantee a quicker car.......as things have changed. A new cam and convertor would have made the car quicker before as well.......so figuring out the proper direction is key in this situation......Those were also the first passes with the new combination and there are so many things to work with before throwing money and parts at it.....should be as clear as mud........D
devildog
