Engine....................
+25
BigDave65
665 falcon
KY JELLY
kevinlvy
342g
hillbillyerv
Lonewolf1970
56Tbird
Bsherry
'65 T-BOLT
Larry Williams
Oakley Motorsports
bb429power
29 posters
Page 3 of 5 Previous  1, 2, 3, 4, 5  Next
Engine.................... - Page 3 Empty Re: Engine....................
Post  Lem Evans December 19th 2010, 7:57 pm
Engine.................... - Page 3 Larryw004Medium
Engine.................... - Page 3 Larryw003Medium
Engine.................... - Page 3 Larryw002Medium
Engine.................... - Page 3 Larryw001Medium
Post  richter69 December 19th 2010, 8:15 pm
nice oil heater................. cheers
Post  Larry Williams December 19th 2010, 8:19 pm
cheers cheers cheers cheers santa
Larry Williams
Larry Williams
Post  Lem Evans December 19th 2010, 8:20 pm
Hillbilly heater Wink
Post  richter69 December 19th 2010, 8:22 pm
I've actually built a fire under a dozer in the wintertime................. Wink
I see it has a real coil on it as well.............
Post  138 December 19th 2010, 8:28 pm
richter69 wrote:nice oil heater................. cheers
what is it a halogen light?... Idea
138
Post  Lem Evans December 19th 2010, 8:46 pm
I think that's what it is called Smile It really does help keep heat in the oil between pulls.
Post  c.evans December 19th 2010, 11:49 pm
Guys,
This engine made excellent power and torque throughout it's rpm range. IMO it is the best 598 single carb, A-460 headed engine that has ever been on the dyno here in Owensboro. Phillip, Lem, and Lawes have a right to be proud of their efforts. Congratulations!
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  138 December 20th 2010, 12:16 am
any info on the compression? and did you work the heads charlie?
138
Post  Oakley Motorsports December 20th 2010, 12:50 am
Charlie thanks for the compliments and Charlie was also involved in the build. This was certainly a great engine to be involved in the build as the customer was great to work with. At this time I dont think the customer wants to be recognized or the particulars on the build. Not trying to be smart just respecting our customer. I will say that Charlie and Lawes were in control of all the head modifications and all 4 of us had a lot of input on those. Pretty cool to work with these guys and we are all still alive. Smile
Oakley Motorsports
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Oakley Motorsports December 20th 2010, 1:00 am
richter69 wrote:I've actually built a fire under a dozer in the wintertime................. Wink
We also dyno with the customers ignition box as you see hanging behind the engine. This is not always possible but try to do it when we can.
Oakley Motorsports
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  richter69 December 20th 2010, 1:15 am
Hey, its what I did, even used my 16v battery to run the it..............
Post  Curt December 20th 2010, 12:15 pm
Did you make any pulls without the vacuum pump to see the HP differences?
Post  Lem Evans December 20th 2010, 12:31 pm
No. the best way to do that test i.m.o. would be pump vs. header evac. The Valve covers are not compatable with the evac breathers. 7" hg was all the engine saw. Phillip and I are not big fans of a lot of vac. with the wet in pan pump set up.
The test I'd like to see , but never will, is how much more power would the same package make with an iron block.
Post  Curt December 20th 2010, 12:36 pm
Well, none the less, it is quite impressive. king
Post  138 December 20th 2010, 12:49 pm
whats the theory behind the iron making more than the aluminum?
138
Post  Larry Williams December 20th 2010, 1:00 pm
richter69 wrote:Hey, its what I did, even used my 16v battery to run the it..............
so thats what broke the dyno !!!
Larry Williams
Larry Williams
Post  dfree383 December 20th 2010, 1:57 pm
138 wrote:whats the theory behind the iron making more than the aluminum?
The iron block is more rigid, allows tighter clearances, better ring seal and less losses due flex in the block.
Post  Lem Evans December 20th 2010, 2:08 pm
Exactly.
Post  IDT-572 December 20th 2010, 6:14 pm
Exactly.
Harder to get the oil temp up too.....................
Post  Lem Evans December 20th 2010, 7:43 pm
It certainly was in this case....I'd like to have seen another 20* of oil temp. for sure for the extra power.
Post  Doug Rahn December 20th 2010, 7:49 pm
You gotta luv those Blue Grass engines Cool
Post  richter69 December 20th 2010, 8:07 pm
Lem Evans wrote:It certainly was in this case....I'd like to have seen another 20* of oil temp. for sure for the extra power.
should have swapped out the 300w for a 500w................. or went and raided Ky's deerstand for some handwarmers and duct taped um on there............. Wink
Post  Lem Evans December 25th 2010, 9:15 pm
Engine.................... - Page 3 CCF12252010_00001
Post  richter69 December 25th 2010, 9:19 pm
been nice to have an external oil pump and go turn the screw up a tad.............................. Wink
