Engine....................
+25
BigDave65
665 falcon
KY JELLY
kevinlvy
342g
hillbillyerv
Lonewolf1970
56Tbird
Bsherry
'65 T-BOLT
Larry Williams
Oakley Motorsports
bb429power
29 posters
Page 4 of 5
Page 4 of 5 • 1, 2, 3, 4, 5
Re: Engine....................
Just depends if you have negitive view or not It's got more pressure at 7,200 than 5,400 rpm.....looks like it hit the bypass at 6,900 rpm.
I agree with you that an external pump is the best piece for this application for sure.
1072 horsepower on one carb is pretty impressive in my opinion.
Nevs- BBF CONTRIBUTOR
my view wasn't negative, I have a external pump so i know its worth................
the engine has finally found a home
Larry Williams- Posts : 884
Lem Evans wrote:
looks like it is still missing something
its in the chassis now but I can't post pics
PIcs or I'd didn't happen.....
the picture made it to my avatar
I still don't believe you. Just kidding. Lookin' goooood !!
cletus66- Posts : 865
WOW that is one nice build, I would love to have a setup like this one.
CHARLIEB- Posts : 145
CHARLIEB wrote:WOW that is one nice build, I would love to have a setup like this one.
You can
I hope so soon I like its a lot of horsepower and pump gas I dont how good it will run on the street
GA Dragster engine ?
That motor is a beast and I have to have one, I dont care if I am able to drive it on the street much, I just like to have all that Hosepower under my hood so when I do take it to the local hangout they will know it will run and just not looks.
Lem Evans wrote:Just depends if you have negitive view or not It's got more pressure at 7,200 than 5,400 rpm.....looks like it hit the bypass at 6,900 rpm.
so what is the advantage of an exteral pump ?
Looks fast....
1] external adjustable pressurebruno wrote:Lem Evans wrote:Just depends if you have negitive view or not It's got more pressure at 7,200 than 5,400 rpm.....looks like it hit the bypass at 6,900 rpm.
2] """""""""""""""""""""" pump speed
3] Fabio has one
Awwww hell if Fabio has one...... We all need at least two !!
that engine is home at last
Lem Evans wrote:1] external adjustable pressurebruno wrote:Lem Evans wrote:Just depends if you have negitive view or not It's got more pressure at 7,200 than 5,400 rpm.....looks like it hit the bypass at 6,900 rpm.
3] Fabio has one
Plus it also takes a big load off of the distributor drive gear (it should never shear off a pin) and the timing is more stable.
ive run the same bronze dizzy gear for like 8 years now, looks like i pulled it out of the package........
richter69 wrote:ive run the same bronze dizzy gear for like 8 years now, looks like i pulled it out of the package........
Same here, since 2005.
"Plus it also takes a big load off of the distributor drive gear (it should never shear off a pin) and the timing is more stable".
X3
gets it out of the pan so you can put a full windage tray/screen in there also
» 514ci BLUE THUNDER HEADED ENGINE & bbf parts,and engine for sale
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» C9VE engine from 69 Continental -- Have questions about where to go with this engine
» Engine Masters 414" stroker 351W street/strip engine
Page 4 of 5
