What's she gonna run?
+21
5pointslow
f250mike
460vega
dirt_worker
bluef100fe
bigblok2000ranger
lghting94
79ford pickup
56Tbird
whitefield
61coon
OldRed70
bb429power
25 posters
Page 3 of 6 Previous  1, 2, 3, 4, 5, 6  Next
What's she gonna run? - Page 3 Empty Re: What's she gonna run?
Post  dirt_worker April 3rd 2013, 8:00 pm
For what its worth...when I still had a 429 in mine (420 hp@the tire) it too was a dog on the bottom and ran mid 12s @ 4100 lbs.
it had a xr286r solid roller...victor intake and hp 950
dirt_worker
dirt_worker
Post  460vega April 4th 2013, 5:05 pm
My brother has a 65 f100, had a 466/c6 combo in it & it ran 11.60s, it ran 7.30 in the 1/8th but hit that wall of air on the top end. The motor had dished trw pistons, home ported doves, solid ft cam, tunnel ram w/2 660 carbs, about 4200 lbs.
460vega
460vega
Post  f250mike April 4th 2013, 8:31 pm
Justin, if it doesn't spin a ton off the line I think mid 13's is realistic.
I started out running high 12's with my truck 4 years ago. With the help of the guys here over the last few years, it went 11.44 the last pass of last year.
Listen and learn my friend!!
Oh and don't let the disease over power
your wallet!!!!!!!!!!!!!!!!!!!!!!
mike
f250mike
f250mike
Post  69F100 April 4th 2013, 11:43 pm
f250mike wrote:Justin, if it doesn't spin a ton off the line I think mid 13's is realistic.
mike
X2 Very Happy
Post  bb429power April 5th 2013, 11:01 am
Well after this race I can hopefully make some changes, I need to sell/trade some stuff to make it happen though. I'm broke, but what else would I spend my money on anyways? Razz still on the search for a job, I have a bunch of good paying jobs offered to me up here, but absolutely nothing down at school where I need one Rolling Eyes I gotta get that cash flowing again big time. Then I can get this baby completed, minus the changes in the distant future
bb429power
bb429power
Post  whitefield April 11th 2013, 3:50 pm
Is she going to be able to run by the 27th ? Smile
whitefield
whitefield
Post  bb429power April 11th 2013, 11:13 pm
Pretty much just sitting around twiddling my thumbs now Laughing Waiting on my shocks and a roll bar kit before I can install my harness. This roll cage will take a bit of work to put in, it has to have different angles and what not than a regular kit. I've been fiddling around with a few things, like brake adjustment, tacked the exhaust up in place for now. It'll come off for the race and I will fully weld it while its out.
On a side note, what size carb do you think would be good for this? I have a buddy with an 850 dp, would that be good or should I get more? From what I hear the 950 flows the same.
bb429power
bb429power
Post  69F100 April 12th 2013, 12:42 am
bb429power wrote:Pretty much just sitting around twiddling my thumbs now Laughing Waiting on my shocks and a roll bar kit before I can install my harness. This roll cage will take a bit of work to put in, it has to have different angles and what not than a regular kit. I've been fiddling around with a few things, like brake adjustment, tacked the exhaust up in place for now. It'll come off for the race and I will fully weld it while its out.
Use his 850 and see how it does if it don't do the job then buy a 950
Post  jasonf April 12th 2013, 7:44 am
IDT-572 wrote:That is the times my 2002 lightning runs on street tires, your truck should do that if you have it right.
I've rode in your lightening and it is freaking fast for a pretty stock truck. It felt way faster then my 79 F159 460 truck. Of course mine didn't have a "Snake" tune.
Post  bb429power April 14th 2013, 12:45 am
Took her out for the first time, left a few 11's around town. I was only able to get up to 2,000 on the converter but I think the brakes aren't strong enough to hold it past that right now. This thing pulls harder than the maverick ever did, idles down fine whem I come to a stop. I have to pull my intake because it's leaky right now but I will be checking everything over. The only issue I seemed to have was the 1-2 shift. It didn't want to shift at wot, let off real quick and it shifts.
bb429power
bb429power
Post  schmitty April 14th 2013, 9:51 am
Are you shifting manually, or just putting it in Drive and letting the trans shift itself?
Post  bb429power April 14th 2013, 11:01 am
Manually
bb429power
bb429power
Post  whitefield April 14th 2013, 11:22 am
bb429power wrote:Manually
What kind of shift kit do you have and modulator valve ? also how do you have the modulator adjusted ?
X2 on running the 850 carb.
Whatever it runs have fun and don't be disapointed in it! Cool
Also my son has an 02 Lightning with crower cams , ported blower 3000 ss converter upper and lower pulley's, Borla exhaust, dyno tuned, traction bars and 12" wide rims with M&H drag radials that are 390/40/17. . At 5000lbs with driver full tank of gas in the heat just went 7.97 1/8 mile and the year before that and before the ported blower at BG KY went 12.76 1/4 mile. Just something to think about , don't want you to be disapointed !
whitefield
whitefield
Post  bb429power April 14th 2013, 6:22 pm
Its just stock stuff except the converter. Until I can put a shift kit in it.
bb429power
bb429power
Post  bb429power April 23rd 2013, 11:26 pm
Well, I will be back Thursday night to finish things up. I have a 6 point roll bar going in, I have the 4 point part of it welded and setting in place. I want to hold off on the side bars because they seem too low for tech (I think). But anyways, I have to tighten the bolts and at some point weld the plates around the side. I have a sunburn from welding, that hasn't happened since my welding class Laughing I have to double check everything, and I mean just about everything. I changed my modulator valve to a green stripe, and have a shift kit to install but I think it'd be in my best interest to wait and avoid rushing it and doing it two, three times. I think I'll suffer from wheel hop until I get caltracs on it, I might be able to adjust my shocks tight to help that.
My friend backed out of the carburetor after I had sold some stuff and had the money. So I'll be looking still. Got b-day money and some of my tax return so I have a wee bit of money to spend, only enough to buy one thing probably. I really want to know what it'll run, like I said even with everything like the small carb, bad shifting, heavy truck, tight converter, ect. It pulls a lot harder than the maverick. Dad keeps saying how fast it was when he rode in it, I hope it impresses the hell out of me and makes me real proud to have built it. I'm real surprised with how loud it is with the low compression, about to pull the exhaust off for the race this Saturday and to fully weld it, it's gonna get loud! bounce I will get some GoPro footage. Oh and something else, what pressure do you think I should put my tires at as a good starting point? M/T ET Streets, 315/60r15.
bb429power
bb429power
Post  bluef100fe April 24th 2013, 4:18 pm
My truck liked 25psi best with the drag radials and foot braking. Now with the slicks and a Transbrake its a whole different story... lol good luck and most importantly have fun.... fwiw when I was foot braking my truck I didn't have anything fancy done with the suspension and it didn't hop...
bluef100fe
bluef100fe
Post  f250mike April 24th 2013, 8:45 pm
Justin, Cody is right! Have fun!!
Last year I broke out at every race after I took out the transfercase. It got even worse after I swapped from the stealth intake to the victor.
2 years ago I always ran a 12.0 something in the 12,00 index class. Won 2 of 5 races and finished 2nd in points
Last year my slowest was 11.79 with 11.44 being my worst/best pass Very Happy
Even though I lost every race, I had a blast.
mike
f250mike
f250mike
Post  bb429power April 24th 2013, 9:08 pm
See, it's fun either way, but I like being able to race more rounds because the fun lasts longer. I get to mess with the car and go through everything, which is why I love T&T racing. I can relax and me and my dad have time to tune everything and learn more.
bb429power
bb429power
Post  bb429power April 28th 2013, 7:10 pm
Well, she surprised the hell outta me! Ran a 13.0 with no tuning, and not shifting worth crap. I didn't make it too far, but I don't care. It was a great day, I got the truck out there and it ran faster than I expected. After I put a shift kit in I will hit 12's easily, then even more once I get to tuning it. I would have hit 12's on my one run based on the faster 60 ft. but the guy next to me never left the line so I let off to play it safe.
bb429power
bb429power
Post  bb429power April 28th 2013, 7:16 pm
Also, how much would I benefit from a caltrac or slapper bar setup being that I already hook? I have adjustability on the rear shocks both ways still, and the tires were at 25 psi. I didn't touch anything and left the tune how it was for the day.
bb429power
bb429power
Post  dirt_worker April 28th 2013, 7:27 pm
Great job justin!
At your level id only be concerned about controlling wheel hop....if its not doin that i wouldnt waste you $$ on the caltracs. I ran cheapo traction bars down to about 11:40 on mine before it was time for a better setup.
dirt_worker
dirt_worker
Post  whitefield April 28th 2013, 8:17 pm
Very good! Cool keep at it and it will go faster and be funner cheers
whitefield
whitefield
Post  69F100 April 28th 2013, 9:28 pm
Justin Very Good She will suprize you alittle more to get the little bugs worked Laughing Smile Very Happy
Post  460vega April 28th 2013, 9:38 pm
Good job! Get that tranny fixed before it burns up & it`ll run well in the 12s. Gotta love bbfs!
460vega
460vega
Post  5pointslow April 29th 2013, 6:38 am
nice job man .......must be nice just to enjoy it and make some passes out of it !!!
5pointslow
5pointslow
