Update-Hy-Gard made the converter too tight?
+11
BIGDOG466
85montess
badshoe
Treeyasoon
15 posters
Page 3 of 4 Previous  1, 2, 3, 4  Next
Update-Hy-Gard made the converter too tight? - Page 3 Empty Re: Update-Hy-Gard made the converter too tight?
Post  BIGDOG466 June 21st 2010, 6:13 pm
I have a 4.30 and a 5.14 gear set, and don't forget the convertor deal!!!!!!!!!!
BIGDOG466
BIGDOG466
Post  whatbumper June 21st 2010, 8:32 pm
On a side note.
With the Tractor Supply brand fluid we say a stall difference but with the thinner JD oil we don't see any difference. We run JD oil because it is cheap for us (we farm and get it in 250gal bulk tanks) and the flash point (fire) is higher which is important with our turbo deal. We've been running JD oil since 1998 in all our trans.
I sell a lot of Amsoil Compressor oil to guys around the country and they seem to love it but we figured what we have is working so why change.
Update-Hy-Gard made the converter too tight? - Page 3 Empty Dyno Sheets
Post  Treeyasoon June 21st 2010, 8:49 pm
I found the old dyno sheet but I can't find the cam card to save my ass...I will call Crower with the numbers and see what they have on it...It is less difference than I remembered it to be....
Update-Hy-Gard made the converter too tight? - Page 3 Img075
Current deal...
Update-Hy-Gard made the converter too tight? - Page 3 Img052-1
Treeyasoon
Treeyasoon
Post  cool40 June 21st 2010, 10:15 pm
you've traded tq for hp.i'd change the cam.i think you can keep your hp and get the tq back and haul some ass with it.with a BBF tq is free,hp cost money. Laughing
Post  Treeyasoon June 21st 2010, 10:41 pm
At 5000 rpm the new cam is actually making close to the same torque...It seems to me they are not too far off?
The columns for torque and hp are flipped from one sheet to another.
Treeyasoon
Treeyasoon
Post  cool40 June 21st 2010, 11:06 pm
that'd be more like it. Laughing i dont read instructions or ask for directions either. Laughing if your will'n to turn it a little harder put some more gear in it and it should help.it's gona be one of them "sweet spot"deals for sure. Smile
Post  IDT-572 June 22nd 2010, 9:04 am
Just put a 5800 - 6000 converter in it and it will run now................. Twisted Evil
Post  Treeyasoon June 22nd 2010, 9:07 am
Hey Blake...do the torque numbers look too far off to you? I'll yank the converter out and have it loosened up if need be.
Thanks,
Jeff
Treeyasoon
Treeyasoon
Post  IDT-572 June 22nd 2010, 9:17 am
Treeyasoon wrote:Hey Blake...do the torque numbers look too far off to you? I'll yank the converter out and have it loosened up if need be.
Thanks,
Jeff
No, not for the cam you have. Your making with in 5.4 ft lb's of the other cam and it's a good bit higher in the torque curve. In my opinion it will be faster with the new cam. I don't think the new cam is right for your engine but it will run faster when you get the converter leaving 300-400 above the torque peak.
But that being said , your going to have to shift it much higher than you did before. Just keep moving your shift point up until it gets as fast as it will run, or until you don't feel comfortable turning it anymore.
It should be faster than it was before, even with the tall gears you have.
Update-Hy-Gard made the converter too tight? - Page 3 Empty I appreciate it guys....
Post  Treeyasoon June 22nd 2010, 5:29 pm
Thanks for all the input fellas...I've never really had to run my stuff hard to go fast but, it looks like this deal wants the screw turned a little more...which is O.K. because the chassis seems to like it. I'll change the fluid, crank up the lauch and shift and let 'er eat.
I'll let ya'll know what happens........"Hold on tight to your saddle horn son...."Update-Hy-Gard made the converter too tight? - Page 3 Icon_super
Again, thanks for the help.
Jeff
Treeyasoon
Treeyasoon
Post  IDT-572 June 22nd 2010, 5:43 pm
Treeyasoon wrote:Thanks for all the input fellas...I've never really had to run my stuff hard to go fast but, it looks like this deal wants the screw turned a little more...which is O.K. because the chassis seems to like it. I'll change the fluid, crank up the lauch and shift and let 'er eat.
Jeff
No such thing as too much Cow Bell................. Evil or Very Mad Cool Laughing
Post  richter69 June 22nd 2010, 6:32 pm
yeah after looking at both sheets I's say the converter is more at fault here. If Coan cant get it right i know a fella that can...................
Twist that bitch...................... Cool Lugging it is worse IMO.
Post  BIGDOG466 June 22nd 2010, 7:54 pm
dfree383 wrote:Hy-Guard is a specific Brand Fluid by / For John Deere Tractors........ not the stuff you just said you used.... Houston, we have a subsitute !!! Laughing
No No Mrs. Butterworths ,,,,,,, Low Vis Hy-Gard
study study You buy'um books and buy'um but do they listen!!!!!!!!! lol! lol!
BIGDOG466
BIGDOG466
Post  Treeyasoon June 22nd 2010, 8:28 pm
Yea...it looked like some warm pancake syrup.... Very Happy
Here is the original cam......If anyone is still curious.
Update-Hy-Gard made the converter too tight? - Page 3 Img076-1
Treeyasoon
Treeyasoon
Post  Lem Evans June 22nd 2010, 8:32 pm
Yes, i'm curious about what the card says Smile
Post  Treeyasoon June 22nd 2010, 8:33 pm
I re-sized it...couldn't read it before...
Lem...If the card "says" anything...I might join the Circus with it. :D
Treeyasoon
Treeyasoon
Post  Lem Evans June 22nd 2010, 8:52 pm
Looks like 280*/286* ?
Post  Treeyasoon June 22nd 2010, 9:16 pm
10-4
Treeyasoon
Treeyasoon
Post  IDT-572 June 22nd 2010, 11:05 pm
Old cam doesn't have enough split and the new cam is to big at .050 on the intake and to much overlap.
My vote is a cam and converter change............. But I know money can be a problem sometimes.
Post  Tony M June 23rd 2010, 12:40 am
If my memory serves me well the Lo Vis Hy Gard is Hyrostatic Fluid which can also be subsituted with 10w motor oil. HyGard is hydraulic fluid similar to coventional trans fluid. (its been along time but I used work for a JD (yellow) dealership)
Tony M
Tony M
Post  Lem Evans June 23rd 2010, 9:35 am
IDT-572 wrote:Old cam doesn't have enough split and the new cam is to big at .050 on the intake and to much overlap.
And, when the exh. duration gets bigger it may need a little wider lsa. Some more lift would not hurt either.
Post  D. Sea June 23rd 2010, 12:27 pm
Jeff
Except at Bowling Green at the NMRA World Finals '08 Twisted Evil
Where did you hang the tail light? In your shop?
D. Sea
D. Sea
Post  IDT-572 June 23rd 2010, 12:28 pm
Jeff
Yep it is in the shop............ I guess that was to much Cow Bell............. Shocked Laughing
Post  IDT-572 June 23rd 2010, 12:29 pm
Hope to have two laying on the track this year Twisted Evil affraid
Post  Treeyasoon June 28th 2010, 10:22 am
Just an update....I swapped out the fluid for some red stuff and it loosened the stall back up somewhat. I was watching the tach at the shift and it was falling back to 5600, which I think is fairly close.
I did not change the launch (3900) but I did turn the shift up to 6800, which it liked....didn't want to change too much at once.
The DA was at 4500' this weekend. I went through some old log books to see how it compared to similar conditions...turns out, I am only about a tenth off from where it used to be.
The tires I have on now are the tallest I have ran....(105 1/2" rollout.) A friend of mine has ran this tire before with a 565" BBC door car and they slowed him down almost a tenth vs. a 14X32" stiff sidewall. (Which is the tire I used to run.)
I'm gonna test again Wednesday and crank up the launch to about 5200 or so and see what happens.
Last edited by Treeyasoon on June 28th 2010, 11:23 am; edited 1 time in total (Reason for editing : typo)
Treeyasoon
Treeyasoon
