My new 528 combo
+26
whitefield
ThndrChkn
quick 52
QtrWarrior
66prostreetfairlane
'65 T-BOLT
dtimmer
fordpullin
levy87
bigjohn2007
yellowhorse7
Barney
bigblok2000ranger
30 posters
Page 12 of 17 Previous  1 ... 7 ... 11, 12, 13 ... 17  Next
My new 528 combo - Page 12 Empty Re: My new 528 combo
Post  bigblok2000ranger July 19th 2012, 6:57 pm
Yeah they do! I am gonna focus on removing weight from the front end of truck mainly (cab forward). I think removing rear weight would be counterproductive to traction at this point. I may have to get a plasma cutter sooner than later to assist in removing weight (just another good excuse to get a new tool Wink )
bigblok2000ranger
bigblok2000ranger
Post  ThndrChkn July 21st 2012, 1:12 pm
bigblok2000ranger wrote: I may have to get a plasma cutter sooner than later to assist in removing weight (just another good excuse to get a new tool Wink )
Go ahead!! You know you want to... Very Happy
ThndrChkn
ThndrChkn
Post  BOSS 429 July 21st 2012, 1:25 pm
bigblok2000ranger wrote:Yeah they do! I am gonna focus on removing weight from the front end of truck mainly (cab forward). I think removing rear weight would be counterproductive to traction at this point. I may have to get a plasma cutter sooner than later to assist in removing weight (just another good excuse to get a new tool Wink )
your num not working? call me from somewhere
Post  bigblok2000ranger July 21st 2012, 6:36 pm
Been having charging issues with it I will call in a few it is finally charging.
bigblok2000ranger
bigblok2000ranger
Post  bigblok2000ranger July 26th 2012, 10:39 pm
If it's not raining will be testing Sunday. Very Happy Very Happy Very Happy
bigblok2000ranger
bigblok2000ranger
Post  bigblok2000ranger July 30th 2012, 1:07 am
It went down the track straight Smile I left some important tools at home because of being in a rush Sad working on a checklist for next outing and gonna have to get a good plug socket. Important lesson learned today; when building headers need to make sure I have sufficient room to remove plugs easily!
bigblok2000ranger
bigblok2000ranger
Post  Mark Miller July 30th 2012, 1:53 am
It sounds like my cousins Mustang with A-460 Heads it's not fun getting his plugs out very tight.
Later Mark.
Post  bigblok2000ranger July 30th 2012, 3:13 pm
Yeah mine isn't horrible but I took the rubber piece out years ago because the socket kept getting stuck doing the plugs on overhead cam engines so I need to get a new one. I forgot about that and cracked the porcelain on a couple.
bigblok2000ranger
bigblok2000ranger
Post  yellowhorse7 July 30th 2012, 4:15 pm
bigblok2000ranger wrote:Yeah mine isn't horrible but I took the rubber piece out years ago because the socket kept getting stuck doing the plugs on overhead cam engines so I need to get a new one. I forgot about that and cracked the porcelain on a couple.
So how many hits did you make????
yellowhorse7
yellowhorse7
Post  bruno July 30th 2012, 4:30 pm
SO WHAT DID IT RUN ??????
http://WWW.CKRME.COM
Post  the Coug July 30th 2012, 4:44 pm
bruno wrote:SO WHAT DID IT RUN ??????
Bruno you don't have a decoder ring so drop it....
Post  bigblok2000ranger July 30th 2012, 6:54 pm
Just one 1/8 mile hit.
LOL, it was more to make sure nothing fell off the truck than anything so it don't matter much. I am going again next Sunday and gonna be better prepped so maybe we will learn something then.
bigblok2000ranger
bigblok2000ranger
Post  yellowhorse7 July 30th 2012, 8:03 pm
I have that ring....I know what it ran Laughing
yellowhorse7
yellowhorse7
Post  bigblok2000ranger August 1st 2012, 7:42 pm
yellowhorse7 wrote:I have that ring....I know what it ran Laughing
LOL Smile We will see what it does this weekend off the brake, I have a power master cylinder that is converted to manual so it wouldn't hold back enough to get up on the converter. I may get a manual one this weekend.
bigblok2000ranger
bigblok2000ranger
Post  bigblok2000ranger August 5th 2012, 7:24 am
Sitting at the track with the truck on the trailer, pulled an all lighter due to the fuel pump leaking. Last weekend it started as a weep then a drip and when I turned the pump on yesterday it started pouring out, replaced the motor to pump seal with a neoprene washer that was thicker than what was left of the old gasket and put an oring on the shaft to seal off the motor from fuel so hopefully its fixed or this may be a short day.
bigblok2000ranger
bigblok2000ranger
Post  bigblok2000ranger August 6th 2012, 6:48 pm
My first quarter mile pass was not very good but that was half my fault and half my suspension, the truck was trying to pull the front tires off the ground near the 1/8 mile at about 100mph. I got some major attention when I let off the transbrake and it launched hard enough to pull the back wheels about 3-4 inchs off the ground.
bigblok2000ranger
bigblok2000ranger
Post  Mike R August 6th 2012, 7:24 pm
Sounds like you're going to have your hands full cheers
Post  whitefield August 6th 2012, 8:13 pm
bigblok2000ranger wrote:My first quarter mile pass was not very good but that was half my fault and half my suspension, the truck was trying to pull the front tires off the ground near the 1/8 mile at about 100mph. I got some major attention when I let off the transbrake and it launched hard enough to pull the back wheels about 3-4 inchs off the ground.
Sounds like you gotta kickin chicken ! Giver a gallon and let the Hairy side drag bounce bounce bounce
whitefield
whitefield
Post  yellowhorse7 August 6th 2012, 8:31 pm
bigblok2000ranger wrote:. launched hard enough to pull the back wheels about 3-4 inchs off the ground.
Explain
yellowhorse7
yellowhorse7
Post  BOSS 429 August 6th 2012, 8:46 pm
WELL when he let go of the button it went straight up to about 2 feet or more in the front ,with it came the rear tires off the ground ,when they touched it blew them off and it turned right
Post  bigblok2000ranger August 6th 2012, 9:08 pm
Its getting some work done before it goes back out, gonna move the radiator forward so I can put the fan on the back of the radiator and create some clearance to install a decent lower hose and gonna lower the whole truck about 2 - 2 1/2 inchs.
bigblok2000ranger
bigblok2000ranger
Post  res0rli9 August 7th 2012, 2:24 am
YEE-HA!!! Ride-em cowboy cheers Smile
Post  bigblok2000ranger August 10th 2012, 8:26 pm
I got some parts ordered for the suspension today and recieved my housing floater kit from Jegs, there is a little more assembly than what they show in the advertisement for them but I have plenty of gas and wire in the welder. Chris is selling my a set of Chassis Engineering ladderbars off his truck so I ordered housing brackets and a cross member kit from them today should be here tuesday or wednesday, I was gonna have them overnight it but they told me UPS has gone crazy on their charges to overnight stuff and it would have almost doubled the cost. I will be lowering the front end tomorrow morning. Hoping the ladderbars with housing floaters and frontend work will get this thing down the track for now, if not the next stage will be coilovers and some fat tires underneath it. Iwould like to get this thing in the 8's before the track closes which I know it's definitely got the power to do.
I know I know someone is gonna question the ladderbars but it is more of a packaging issue and they can work at this level.
bigblok2000ranger
bigblok2000ranger
Post  cool40 August 10th 2012, 8:31 pm
whats wrong with ladder bars? i run them under my car and will as long as i can hook it up. on your truck thats what i'd use too.
Post  bigblok2000ranger August 10th 2012, 8:56 pm
cool40 wrote:whats wrong with ladder bars? i run them under my car and will as long as i can hook it up. on your truck thats what i'd use too.
Nothing wrong with them in my opinion just everytime I say something about using them a bunch of people ask why not a 4 link.
bigblok2000ranger
bigblok2000ranger
