My new 528 combo
+26
whitefield
ThndrChkn
quick 52
QtrWarrior
66prostreetfairlane
'65 T-BOLT
dtimmer
fordpullin
levy87
bigjohn2007
yellowhorse7
Barney
bigblok2000ranger
30 posters
Page 14 of 17
Page 14 of 17 • 1 ... 8 ... 13, 14, 15, 16, 17
Re: My new 528 combo
sounds like you are down on power you need another 20 mph to run in the 8's hope you can tune that much. the 60's will come but a 20 mph pick up is alot
quick 52- Posts : 612
bigblok2000ranger wrote:It pulled 135 in the quarter with the plugs loading up for first half of track, gonna blow out the air bleeds think mights picked up some trash.
something is way off , it should mph in the high 50's , my eddies mph 155 in the 1/4 n/a ......... what carb is on there ?
OK guys, it was loading up the plugs in the staging lanes and didn't clean out til the top end of second gear just shy of the 1/8 mile. Jason and Rich think I may have sucked something into the air bleeds, I am gonna clean the carbs out this week, the 60' was low because it spun, I was pleased regardless because it was carrying the front tires about 3-4 inchs off the ground as it was spinning and going forward, I believe I finally have some useful data to work with. I am thinking of lowering the bars one hole to stop the spinning.
The truck is heavy! Probably won't get into the 8's til I get some weight off but we believe should be able to go really low nines yet this year.
bigblok2000ranger wrote:OK guys, it was loading up the plugs in the staging lanes and didn't clean out til the top end of second gear just shy of the 1/8 mile. Jason and Rich think I may have sucked something into the air bleeds, I am gonna clean the carbs out this week, the 60' was low because it spun, I was pleased regardless because it was carrying the front tires about 3-4 inchs off the ground as it was spinning and going forward, I believe I finally have some useful data to work with. I am thinking of lowering the bars one hole to stop the spinning.
Rich Wilhelm from Circle R Racing is building the engine and we are hoping to make 1000+hp@8000rpm's. Hoping this combo will run 8.20-8.30's in the quarter when we lean on it.
bruno wrote:bigblok2000ranger wrote:OK guys, it was loading up the plugs in the staging lanes and didn't clean out til the top end of second gear just shy of the 1/8 mile. Jason and Rich think I may have sucked something into the air bleeds, I am gonna clean the carbs out this week, the 60' was low because it spun, I was pleased regardless because it was carrying the front tires about 3-4 inchs off the ground as it was spinning and going forward, I believe I finally have some useful data to work with. I am thinking of lowering the bars one hole to stop the spinning.
The truck is 450 pounds heavier than we thought so not gonna happen this year. Jason took all my data from my pass and calculated and it making close to what it needs even with the fouled plugs to run.
He has issues other than HP, that he needs to work out, all your seeing is new combo blues..............
It will come around in time.
bigblok2000ranger wrote:bruno wrote:bigblok2000ranger wrote:OK guys, it was loading up the plugs in the staging lanes and didn't clean out til the top end of second gear just shy of the 1/8 mile. Jason and Rich think I may have sucked something into the air bleeds, I am gonna clean the carbs out this week, the 60' was low because it spun, I was pleased regardless because it was carrying the front tires about 3-4 inchs off the ground as it was spinning and going forward, I believe I finally have some useful data to work with. I am thinking of lowering the bars one hole to stop the spinning.
im not agruing with you , im happy the truck is getting down the track ....just the mph seems really low for a 1000hp a headed deal ........ get back out there and get that carb cleaned up !!!!!
agreed it aint the hp, its everything else around it ..............new territory.
Besides the odvious tire / suspenion issues your having.
What fuel system you running? What kind of cell? Lines? Etc. Have you cleaned everything out & verified the pump is flowing enough?
I wish you would have dyno'd it that generally make things a little easier to figure out.
It's probably a good thing its a little down on power right mow, it gives you a chance to get the truck sorted out before you really put the screws to it. Tons of power without the truck working right is a recipe for disaster. Keep it on moo until you get it to work. You got time to figure it out, the race is long.
What's the weather suppose to be up there this week-end?
342g- BBF CONTRIBUTOR
ed]Rich Wilhelm from Circle R Racing is building the engine and we are hoping to make 1000+hp@8000rpm's. Hoping this combo will run 8.20-8.30's in the quarter when we lean on it.[/quote]
It wont make that on motor
BOSS 429- Posts : 2372
Bump for a good deal?
yellowhorse7- Posts : 1382
^^^^^ hey thats my line!!!!.......
OK I was happy with it this weekend! Did it spin, yes but it went straight carrying the tires just above the track as it was spinning. The bars are set in the neutral position at the front with reload in PS bar and it didn't push the rim into the pavement so putting them down one hole may solve the spinning. Yes the MPH was low but the plugs were loaded up that's a simple fix, and it probably woulds gained 10 MPH just from running cleanly not to mention what it woulda. Gained had it not spun. I learned I need a chute my brakes did not like slowing it down from 135.
I feel that is all good info so I am happy! Saturday I am gonna put the bars down one hole and clean the airbleeds and will be shutting down at 1000' til I get a chute. THE TRUCK is finally coming around which is pleasing and the MPH. And ET. Will follow suit.
That's all that matters, as long as your happy with the progress your making with the truck and having fun what else can you ask for. Just keep after it. If I had a nickel for every time my junk didn't do what it was supposed I'd be rich. Just be safe and enjoy the ride.
bigblok2000ranger wrote:OK I was happy with it this weekend! Did it spin, yes but it went straight carrying the tires just above the track as it was spinning. The bars are set in the neutral position at the front with reload in PS bar and it didn't push the rim into the pavement so putting them down one hole may solve the spinning. Yes the MPH was low but the plugs were loaded up that's a simple fix, and it probably woulds gained 10 MPH just from running cleanly not to mention what it woulda. Gained had it not spun. I learned I need a chute my brakes did not like slowing it down from 135.
breath , i didnt mean to come across that way , you have made some great progress with your deal
No prob Nick, its getting there. I learned alot since I first started this thread and the 8.20-8.30's was pretty ignorant statement. Realistically once I get the weight down over winter 8.55-8.65 is where I hope it will be, its not gonna happen this year. I realize that now, I would like to see low nines this year and that will make me very happy.
If it goes low to mid 9s at weight on a 10.5 tire that's a win.bigblok2000ranger wrote:No prob Nick, its getting there. I learned alot since I first started this thread and the 8.20-8.30's was pretty ignorant statement. Realistically once I get the weight down over winter 8.55-8.65 is where I hope it will be, its not gonna happen this year. I realize that now, I would like to see low nines this year and that will make me very happy.
^^^^ agreed, a 8 sec na car takes a bit of doin', more so when your your drivin a closet down through there...............
richter69 wrote:^^^^ agreed, a 8 sec na car takes a bit of doin', more so when your your drivin a closet down through there...............
LOL Closet, refigerator....
Whats the weight of your truck Eric ?
My 69 Mustang is a heavy car due to it's all steel. The engine is 700hp ( been dynoe'd) and my mph in the 1/4 is 137-138 with 4:10's just to give you a reference.
Good luck on sorting it out, it will just take some time and patience
John Myrick- BBF CONTRIBUTOR
Whats your car run in the quarter?
so far 10.18
» Changing gears for nitrous
» It's alive again.
» my new combo
» how much power is it gonna take to push my 88lx into 9.00-9.50 range
» Help with my combo.
» It's alive again.
» my new combo
Page 14 of 17
