cubic inch vs. "the budget"
+29
KY JELLY
lghting94
DanH
Moodyblues
Darrin Gorham
David Willingham
racnrick
605FOX
badcoupe
QtrWarrior
SilvatungDevil
BigDave65
cobra501
33 posters
Page 5 of 9 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
cubic inch vs. "the budget" - Page 5 Empty Re: cubic inch vs. "the budget"
Post  DanH October 18th 2011, 5:11 pm
bruno wrote:
605FOX wrote:what did you decide Bruno ???
nothing yet ..... i have a couple of other projects im working on ....
im thinking about leaving the eddies on there this go around and just changing the stroke/compression like Lem had suggested in a post.
same bore, 4.6 arm for 601 cubes raise the compression to say 14 - 14.5 by milling the head and changing the cam ...what rod will i need ?
like said , don't mill the heads . can use a 6.800 rod with a 4.600 crank , piston ch would be 1.200 " ( approx) depends on deck ht. now .
down side of cutting the heads is you lose piston to valve clearence , top ring placement .to keep p/v clr
DanH
Post  Lem Evans October 18th 2011, 5:28 pm
The cleanest deal would be to use the 4.5" stroke and drop the rod from 6.800" to 6.700" and be able to use your exsisting pistons.
Post  dfree383 October 19th 2011, 2:42 am
I'd be shy about reusing pistons that have had alot of NO2 time on the the stuff is real hard on Rings and Ring lands. IMO get a whole new rotating assy if you want more inches, Don't get cheap on the pistons, it may not be worth it.
Post  bruno October 19th 2011, 7:05 am
dfree383 wrote:I'd be shy about reusing pistons that have had alot of NO2 time on the the stuff is real hard on Rings and Ring lands. IMO get a whole new rotating assy if you want more inches, Don't get cheap on the pistons, it may not be worth it.
sir if the amout of spray i put on these guys messed them up in any fashion , i just need to look at another 1100.00 piston company
i would think the jap crank has had the hardest life in my 2 engines ...just saying
http://WWW.CKRME.COM
Post  dfree383 October 19th 2011, 7:11 am
Exactly how much have you been spraying? How many Runs on the engine?
400+ shots start getting into maintance / Replacement of parts more frequently than a typical NA motor.
Post  bruno October 19th 2011, 7:41 am
dfree383 wrote:
sir if the amount of spray i put on these guys messed them up in any fashion , i just need to look at another 1100.00 piston company
400+ shots start getting into maintenance / Replacement of parts more frequently than a typical NA motor.
ive sprayed the engine with a 73 jet about 25 times( 175 hit), 83 jet about 5 times(225 hit) and the 73jet on the plate and a 20 jet in the fogger 4 times(300-325 hit) @ the bash with the fogger on for 1 sec ......
total runs on this engine probably 100-125 max
Post  dfree383 October 19th 2011, 7:43 am
OK Shouldn't be an issue..... I have a couple of friends spraying big hits and they do wear out rings and lands pretty fast.
Post  bruno October 19th 2011, 11:39 am
dfree383 wrote:OK Shouldn't be an issue..... I have a couple of friends spraying big hits and they do wear out rings and lands pretty fast.
thxs for the input
Post  richter69 October 19th 2011, 12:00 pm
what CC are the heads now Nick?
Post  bruno October 19th 2011, 12:04 pm
richter69 wrote:what CC are the heads now Nick?
72cc
Post  richter69 October 19th 2011, 12:16 pm
I'm with the others, 4.5 crank, 6.7 rod, maybe a mafia intake, get after the fogger....................that combo will get after it and not break the bank.
Post  lghting94 October 19th 2011, 12:17 pm
Some quick calculations show that if all else stayed the same(heads, pistons, head gasket) changing from a 4.300 stroke 6.800 rod to a 4.500 stroke 6.700 rod should gain right at .6 in compression.
lghting94
lghting94
Post  bruno October 19th 2011, 12:23 pm
lghting94 wrote:Some quick calculations show that if all else stayed the same(heads, pistons, head gasket) changing from a 4.300 stroke 6.800 rod to a 4.500 stroke 6.700 rod should gain right at .6 in compression.
right now she is at 13.16
Post  lghting94 October 19th 2011, 12:29 pm
is it possible to run a thinner head gasket to increase compression rather than shave the heads?
lghting94
lghting94
Post  bruno October 19th 2011, 12:29 pm
But still having to buy new pistons
Post  bruno October 19th 2011, 12:30 pm
lghting94 wrote:is it possible to run a thinner head gasket to increase compression rather than shave the heads?
we are running a .040 comp. gasket right now
Post  richter69 October 19th 2011, 12:38 pm
hell unless the deal is hurt I'd leave it be, forget about the plate and get after the fogger with a man shot......bang for the buck right there.
Post  Lem Evans October 19th 2011, 12:44 pm
Put a steel rod in it and the piston can be .010" closer to the head.....more comp. ratio.
Post  IDT-572 October 19th 2011, 12:48 pm
Twisted Evil x2
Post  IDT-572 October 19th 2011, 12:52 pm
4.56x4.5 zero deck .041 gasket 6.8 rod 3 cc relief = more like 15:1 compression
Post  rmcomprandy October 19th 2011, 12:54 pm
It's easiest to change the cam and rear gear, then rev it a bit higher. Piston speed and valve train are the main limiting factors.
Post  richter69 October 19th 2011, 12:56 pm
fix your sig Snake............. Laughing
Post  IDT-572 October 19th 2011, 1:57 pm
richter69 wrote:fix your sig Snake............. Laughing
What do I need to change Question
Post  bruno October 19th 2011, 3:27 pm
rmcomprandy wrote:It's easiest to change the cam and rear gear, then rev it a bit higher. Piston speed and valve train are the main limiting factors.
So what combo would you do ? i just really like the "BIG" factor of the 4.6 x 4.6 ....those eddies do have almost 340cc of intake volume study
Post  Lem Evans October 19th 2011, 4:31 pm
But , it aint got an A460 or C460 exh. port.
