cubic inch vs. "the budget"
+29
KY JELLY
lghting94
DanH
Moodyblues
Darrin Gorham
David Willingham
racnrick
605FOX
badcoupe
QtrWarrior
SilvatungDevil
BigDave65
cobra501
33 posters
Page 6 of 9 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
cubic inch vs. "the budget" - Page 6 Empty Re: cubic inch vs. "the budget"
Post  KY JELLY October 19th 2011, 4:38 pm
you could buy Ky's p-51 heads,cam and pistons, you would not need a ""man shot" then Smile
KY JELLY
KY JELLY
Post  Lem Evans October 19th 2011, 4:46 pm
KY JELLY wrote:you could buy Ky's p-51 heads,cam and pistons, you would not need a ""man shot" then Smile
affraid
Post  bruno October 19th 2011, 5:10 pm
Lem Evans wrote:But , it aint got an A460 or C460 exh. port.
but that is were you make your magic " CAM GOD " Very Happy
http://WWW.CKRME.COM
Post  richter69 October 19th 2011, 5:14 pm
cam will only do so much
Post  the Coug October 19th 2011, 5:23 pm
KY just trade him your engine complete take his in trade and you will still have what you need to increase your engine size....
Post  IDT-572 October 19th 2011, 5:38 pm
IDT-572 wrote:
richter69 wrote:fix your sig Snake............. Laughing
What do I need to change Question
O, I saw what you were talking about, (dyslexic) I guess.............. Rolling Eyes
Post  IDT-572 October 19th 2011, 5:39 pm
Then Nick would be as fast as FABIO...................... Question Shocked affraid scratch study
Post  Lem Evans October 19th 2011, 5:40 pm
You are correct that 'we' can help the deal with a different exh. lobe...but... it's not near a complete solution. If you were to do a 588" with your heads & 14-14.5:1 compression I'd think 4*-5* more duration on the intake side & 6*-7* more on the exh. side.......spread the lsa. Nothing crazy but more lift also.
Post  Lem Evans October 19th 2011, 5:42 pm
I don't think they make a cape that long scratch
Post  Lem Evans October 19th 2011, 5:45 pm
rmcomprandy wrote:It's easiest to change the cam and rear gear, then rev it a bit higher. Piston speed and valve train are the main limiting factors.
If a guy were to change the cam in Nick's present package I'd think a manifold upgrade would be needed to make it the most productive.
Post  bruno October 19th 2011, 6:13 pm
since those heads are machined for those pedestial rollers are we gonna keep that same deal ?
Post  richter69 October 19th 2011, 6:27 pm
so many options..................lol
Post  Lem Evans October 19th 2011, 6:33 pm
Your call...lots of varables that will not be resolved via the keyboard.
Post  richter69 October 19th 2011, 6:42 pm
Resort to phone calls? what the hell.............. Laughing
Post  bruno October 19th 2011, 6:44 pm
richter69 wrote:Resort to phone calls? what the hell.............. Laughing
i can multi-task alot easier via the keyboard/ handling clients on the showroom floor Very Happy the phones here ring off the hook Smile
Post  richter69 October 19th 2011, 6:46 pm
call after business hours............ Very Happy
Post  dfree383 October 19th 2011, 11:44 pm
bruno wrote:
lghting94 wrote:Some quick calculations show that if all else stayed the same(heads, pistons, head gasket) changing from a 4.300 stroke 6.800 rod to a 4.500 stroke 6.700 rod should gain right at .6 in compression.
right now she is at 13.16
Do you realy need a bunch more Compression with the NO2? or do you just need to put the hose to what you have now?
Post  bruno October 20th 2011, 4:54 pm
i would guess to say that another point isnt going to make it that much more difficult to tune ......... i think im more affraid to put the hose to her now with this jap crank
Post  bruno October 20th 2011, 4:55 pm
Lem is there no there no other stroke we can do with these existing rods and pistons ?
Post  IDT-572 October 20th 2011, 4:57 pm
Your existing pistons, rods, and deck height, make up what your stroke will be. IF you change one something else will be effected.
Post  bruno October 20th 2011, 5:33 pm
IDT-572 wrote:Your existing pistons, rods, and deck height, make up what your stroke will be. IF you change one something else will be effected.
cool .....
so which combo will accelerate faster ? n/a
4.50 x 4.560
4.60 x 4.560
4.60 x 4.60
Post  IDT-572 October 20th 2011, 5:56 pm
cool .....
4.50 x 4.560
4.60 x 4.560
4.60 x 4.60
I don't think the extra 13 cubic inch is worth the trouble and cost of putting in the 4.6 crank.
I also think your 4340 RPM crank is as good as any other 4340 crank, other than maybe a Bryant.
As far as accelerating, I don't feel with all else being equal on top of the engine you will see any difference.
You just don't want to get the port velocity to high in the port going to a big cubic inch and small heads.
My 580 inch P-51 deal has port velocity about equal to my 557 TFS Street engine.
Getting the port velocity high, but not too high is the way to a good and powerful engine with a broad torque curve N.A. The port velocity will be high on your Eddy's at 580 + inch and spraying will make them a cork.
With you spraying (Mr Frosty) I think you would be better served to step up to the A heads and a 598 inch, 4.6 x 4.5 And take advantage of the added torque and HP the A heads afford.
Everybody took notice of the hp my P-51's made saying it made A head hp, but nobody notice it was a good 110 ft lb down on torque to Boo Boo's 598 at almost the same RPM. This tells me the A heads raised port aids in cylinder filling even over the P-51's.
You build a good Lem built 598 and stuff a 300 shot through it, I doubt you will make a full throttle pass in two years.
JMHO
Post  richter69 October 20th 2011, 6:12 pm
^^^^^ you'll test the limits of that 8.8 and the rest of the suspension as well.
Post  Lem Evans October 20th 2011, 6:14 pm
Please notice that I referenced 14-14.5:1. While I know the deal can be tuned up for 15:1 I'd feel better about keeping the head gaskets on it with less ratio...given the castings and 10 head bolts/studs. It is my opinion that if the thing won't run , on the hose, with 14.19:1 it aint gonna run.
Post  richter69 October 20th 2011, 6:18 pm
If it were me, I'd gather a set of A460 heads, 4.5 crank, Oliver rods, cam, Intake, etc, etc and stick it under the bed..................tune up the fogger and go race what you have now Nick..........I venture it'll go a good bit faster than what it has. I'd bet the heads will lift long before you blow the crank out of it.
